Just wondering if anyone has a say on the Return Flow type FMIC that are popping up all over the place?
I have been searching around for a decent sized FMIC without going over the top and these have caught my eye due to the fact of no need to cut my REO bar or any other nasty holes in my baby.
Only problems I can see with them at a glance is the fact the return pipe sits VERY low and that nasty bend they often have towards the end of the return pipe. And possibly the sharp change of direction for the air to have to go back towards the turbo.
Just incase I didnt explain it well enough heres a pic of the kit im interested in.
Anyone got some more info on these?
https://www.sau.com.au/forums/topic/310124-return-flow/
  • Replies 40
If you 're worried about how much power you can achieve, you shouldn't be.
My car made 250rwkw with one of these, plus, it has excellent response - meaning that the curvature of the return pipe still allows the air to achieve a smooth flow. The one in the pic is a blitz so it should be fairly efficient.
https://www.sau.com.au/forums/topic/310124-return-flow/#findComment-5110147
i have one of these...
you will probably have to trim your reo a bit, but it's a small price to pay for not having to attack your inner guard with a hole saw!
also re the height clearance, the core is smaller than the usual aftermarket coolers out there, so it doesn't sit ridiculously low (there are only a few light scuffs on mine, in contrast to my mashed up front bar)
do recommend something like this :P
https://www.sau.com.au/forums/topic/310124-return-flow/#findComment-5110151
Not worried about power since I know that beautiful Blitz would flow more than what a RB20 would ever make, just trying to find out info about them from anyone who has one.
Response is all Im after at the end of the day, and Im leaning towards the Blitz ATM due to the fact its only $780 and its Blitz so you know its quality. Or a HPI kit of the same style.
https://www.sau.com.au/forums/topic/310124-return-flow/#findComment-5110155
i currently have a black Blitz return flow on my R33, makes an easy 255rwkw, with the cooler having plenty more left in it. A few people have said they pushed 300rwkw through good quality return flow coolers.
As you said Blitz generally make good stuff, so buy it and enjoy it!!!!
https://www.sau.com.au/forums/topic/310124-return-flow/#findComment-5110232
Thanks heaps for all the replies guys, just the sort of feed back I was looking for.
Also for the ARC side mount, what sort of power would they be able to handle and not really hit its limits? Trying too make sure all the supporting mods are capable of handling much more than what I want to get out of the engine.
Chasing around 300rwhp with as much response as possible.
EDIT - Holy hell just had a quick search for the ARC SMIC for a HCR32 just under $1200, think I'll be sticking with the Blitz at a much more pocket friendly $780
Edited by R32 DORI DORI
https://www.sau.com.au/forums/topic/310124-return-flow/#findComment-5110405
I bought a blitz cs kit and even though i not the most mechanicly minded i still could fit it. I did have to take a fair bit off the stock bumper as you could see. ( better than chopping your chasis though )
Edited by Kenna802
https://www.sau.com.au/forums/topic/310124-return-flow/#findComment-5110854
yes you have to trim the reo to fit the Blitz LM/CS.
And no, the return pipe doesn't sit low. Mine is higher than the factory lip.
And, the flow actually goes through the bottom pipe 1st and then swings into the FMIC :down: Not the other way around. (not that it matters.. just saying :P )
https://www.sau.com.au/forums/topic/310124-return-flow/#findComment-5110944
Would rather shave the front bar than anthing else. Looks really nice though, pretty much what im looking for, even though the FMIC will be blacked out before it goes in <3 Sleepers.
https://www.sau.com.au/forums/topic/310124-return-flow/#findComment-5110954
I always thought about blacking my Blitz out too.. im scared, if i dont like it its kinda hard to go back again..
Whats the saying? 'once you go black you never go back' lol
Im not worried about going back, Black R32 on Black rims. Keeping as low profile in the crowd as possible, not that the Bright red stove tops dont give it away every single time at night.
Plus what it more sexy than a blacked out skyline?
https://www.sau.com.au/forums/topic/310124-return-flow/#findComment-5110967
ARC is expensive because it is high quality japan made
not paying out blitz but yeah ARC make good products
For the power Im chasing I doubt I would see any difference between ARC or Blitz, or even a cheap Cooling Pro FMIC at these levels.
ARC do make brillant products but they are still very pricey, not too fond of paying big just for a name...other than the ARC Airbox. More than happy to fork out the 400 bucks for one of them.
On a side note, anyone know off hand if QLD comes under the same sort of rulings for intake mods as Vic? currently have a pod filter with a custom heat sheild made up.
https://www.sau.com.au/forums/topic/310124-return-flow/#findComment-5110974
    • Would it not be cheaper to just spray nitrous?
    • I've got cash, it's the NA LOLS I'm after now Plus, I've had a few boosted cars, and it is soooo easy to turn a reliable car into a unreliable drivetrain eating money pit monster by just paging up and chasing more My power goal for the NC is to try for a reliable naturally aspirated 150kw or 200hp atw (I'm old, and the old naturally aspirated cherry of 100hp per litre is a goal that I would like to hit), no more is really needed for what I use the car for,  so a additional 5kw is what I'm chasing now,  that 5kw is about $3k away, I think....
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....馃ぃ) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
