Whats it supose to do???
edit
just done a search and hummmmmmm ok then if that can do half of what it says than im a china man
better off getting a neo or a safc or better still
Is there not anywhere in Australia that do generic stage one ECU remaps on an exchange basis?????
Edited by jjskyline79
HI all after hours apoun hours of research and pulling the ecu apart the item is a early version powermod piggy back system. After speaking to powermood.com.au i found there service to be excellent with them even sending me the wiring diagram and fitting instructions to the rb25det. well done to them it hard to find this level of help in an item bought off ebay in which they have no responsiblty for what so ever.
well installed the unit today. hmmmm... Car 1 me 0 installed it all and wont fire. ( i did use spade terminals and splicing connectors ) so will be firing up the soldering iron on the week end and have another go at it. Hopefully it was just a splice connection that was not making contact.
do you have someone that can even tune this system?
never heard of it, and i suspect most tuners will say the same thing
its probably more hassles than its worth honestly
i would have left it at that, cut your losses and buy something well known and locally supported
get a nistune
Good advice there. Nistune is readily available for Rrb25.
NOT
Track down a Z32 ECU, Get a Nis-Tune Board... Then off to the Tuner :D
We've done it to atleast 10x cars by now.
Just need the correct ECU No.
My two cents :down:
Edited by JDM_Spirit
There is a fair bit of support for the power mod system and it is the same distance away from were i live to power mod or nistune tuners. I am a sparky by trade and have some knowledge of how wiring should be done so i would rather just give it another go.
OK round 2 still didnt start but the bloke from powermood said to just run the powermod with out the input /output of the 120 degree senor ( this still just plugs into the normal ecu ). After that it runs so my question is what does the 120 degree sensor do ( i still have the 1 degree sensor inputted into the power mod ) Note this only required to be spliced into not cut .
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
