Towards the end of the year, I am hoping to import a 4-door turbo r32. I have been told by a dude at J-Spec Imports:
...all of this basically means that you will either have to wait until May
2003, or apply for SEVS approval for the R32 sedan and then find a
compliance holder that can already do R32 coupes that might be able to add
the sedan as a variant.
Anyone know who I could turn to for such a task?
At the moment I can't afford a new car, but I would like to do all the research etc now so that when I can afford it I can get straight into it.
Thanks
https://www.sau.com.au/forums/topic/3102-importing-r32-4-doors/
There are already some R32 sedans running around, but these were imported before the laws changed in May this year.
If you look at the current list of approved vehicles, you will clearly see that the R32 is allowed only as a coupe:
SEVS ruling - Nissan Skyline R32
...compared to the R33 Skyline ruling:
SEVS ruling - Nissan Skyline R33
This means that if you really want to import an R32 sedan you would NEED to get it approved under the SEVS scheme (which shouldn't be too hard) and then get a workshop to comply it for you ... for a workshop to be able to do this they must either put in an application to import a test vehicle for this model under the new RAWS scheme which will start in May 2003, or already have R32 coupe compliance and apply to extend their CPA number to inlclude sedans.
i saw the thread about the one for sale
I am interested in it, however i dont have the money for it yet. I wanted to do some research on r32 4 doors now so that when i have my cash i can get the best deal.
I also hear that insurance is a major bitch on skylines for people under 25, so if it's too high then I wont get one for a more years
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
