An apexi boost controller was already installed in my car when I got it.
Im curious to what the original setup looks like incase I need to put it back to stock.
At the moment the hose goes from the inlet pipe to the apexi boost control solenoid to the wastegate.
Is stock straight from the inlet to the wastegate?
https://www.sau.com.au/forums/topic/310238-factory-boost-control/
rb25det
Bottom pipe off stock solenoid t'd into intercooler pipe that runs to actuator
Top pipe off stock solenoid to the pipe that been blocked off
Reconnect boost coupling
IGNORE THE SOLENOID PIPES!!!!
Disconnected
Reconnected
Sorry, car is r33 rb25det.
jjskyline79 you have confused me with those pictures. I've never seen the stock setup remember so I dont know what the stock solenoid looks like.
But from what I understand, if I just go straight from the inlet pipe to the wastgate then I will just get a solid 7psi all the time? If someone can confirm this then that would be good enough for me.
(thinking about getting rid of the 33 and buying a 34, so want to take the apexi controller with me)
Edited by ascenion24
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 馃槈. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 馃槏.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 馃檹 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 馃槈. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 馃槏 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
