Nissan Stagea Rs4 Dayz Edition 1997
Hey guys im selling my Nissan Stagea RS4 Dayz Edition 1997 as i have family emergency's to attend to in Brisbane so i want to sell this as soon as i can... This car has been really well looked after barely driven. Its been in a garage for 6 months... Great Cruise car they are cheap to mod as i was quoted $300 to get a manual box for the stagea so it is a cheap conversion... No prolems what so ever runs a dream...
Nissan Stagea:
Motor
RB25DET
AWD
Auto
145,000kms
Standard Turbo
Splitfire Coilpacks
Aridium plugs
Apexi Boost Controller
Other Stuff
SAFC
Front Stut bar
Boost Gauge
Tien Springs
Turbo back Exhaust 3" with 5" tip
17" Gold GMAX Rims
Fog Lights
Stagea Floor Mats
After Market Roof Racks
New Battery
Central Locking
Tinted Glass
Seat Covers (front)
PRICES: $ 13,000 ONO
No Test Pilots
PM me if anyone is interested or if u want to pm me a price... :down:
Edited by R32NoTiMe4u
 Share
    • After I unplug maf car dies, won’t start. Same with iacv valve - two connectors mounted behind manifold
    • here’s link to photos bcs can’t add it here blue spots - I can install recirc valve hose there and in general everything air intake related so you can spot of anything wrong here
    • Sorry for late answer but here’s my spec: Series 1 1994 r33 gts25t AT converted to MT using r32 rb20det gearbox. Custom self made clutch pedal os giken twin plate clutch two pins connected to let engine start speedsensor from AT connected to wire harness but didn’t fit to gearbox So it’s somewhere inside in the car so I can add km to tachometer after I measure distance with gps. Don’t want to pay 150€ for sensor if I probably will change gearbox with adapter to bmw one. Car barely runs and winter is coming so no point right now  engine after rebuild Stock automatic ecu and at tachometer Aftermarket oil cooler with separate sensor so oem oil pressure is unplugged  koyo 53mil radiator  Mods which may cause the issue: 600x300x76 front mount intercooler Cone air filter blitz Removed recirculating valve Slighty bigger maxspeedingrods turbo adjustable manual boost controller (didn’t set it but last time I checked on aftermarket gauge it was 0.4bar, asaik oem is different unit 7(unit) don’t want to rev it too high bcs it made max 70km after rebuild Fuel pressure regulator set to idk 30-32psi at iddle dw300 fuel pump stock injectors check valve right in front of fuel rail i thinking sth wrong with afr it getting too much fuel and too less air or it needs that recirc valve? on warm engine it took 5-10 seconds to start it. After I put way bigger battery, battery terminals and new ecu coolant temp sensor problem is gone my old turbo spill 150ml oil into intake so cleaned it.    I checked for error codes and it given me 55 - all good. I bought consult so will plug in soon to check if it give me better feedback. Also I will install oem recirc valve tomorrow. Small hose going to manifold but where should go 30mm pipe from this valve? I’m front of turbo inlet, after maf/ right after turbo outlet / or it doesn’t matter? actaully can install it in these two spots (blue circles)
    • I think throwing the hydraulic power steering system into the trash and converting to electric power steering, e.g. Astra PS pump would solve many issues.
