Hey guyz, I need to clear out all the stuff that i have as i need money as im low on money to live :down:
So the list goes on:-
1] R34 Smic[stock intercooler] - It is in good condition, comes with the shroud as well as the stock pipe. Selling it as i have upgraded to a FMIC.. (Price 140$)
2] R34 Hicas[stock Hicas unit]- It is in good condition, perfectly working.. im selling it as i have changed to a hicas lock bar. Can be helpful if anyone wants to put hicas back on and get rid of the light on the dash also.. (Price 50$)
3] R34 Catalytic Converter[stock Cat]- It is in moderate condition and can be used to clear RWC, but still works all fine i changed to a Hi flow cat so had to remove it.. (Price 40$)
4] R34 Front and Dump pipe[stock front and dump pipe] - It is in moderate condition, still working all fine.. can be used to clear RWC , Dont need it as i changed to a 3inch system.. (40$)
5] R34 Spark Plugs[Can be used on other cars also] - Its been on my car for 10,000 km's .. Still works Well, i had to change to different plugs as i increased my boost.. They are NGK Iridium BKR5E11-P... Iridium's can be used for 50,000 km's easily.. There are 6 plugs.. (25$)
https://www.sau.com.au/forums/topic/310277-garage-sale-roadworthy-items/
  • 2 months later...
  • 2 months later...
  • 1 month later...
wanna swap my coilovers for your stock suspension plus cash my way if your running stock suspension for your car? :laugh:
Hey mate, i got some stock suspension thats just sitting in my garage. upgraded to coilovers and dont need them anymore.
Shoot me an offer.
Thanks,
Patrick
  • 4 months later...
