Just picked up a 50mm prime lens today, girlfriend went out to the backyard and took some shots of our pup, thought this was was great, so I'm posting it on her behalf :) Times to get her her own camera me thinks :)
Nice shot. Wish I had a nifty fifty...
ps. pics of missus? :)
Finally finished processing the reception photos from my first ever paid wedding last year. Yes i have been super duper slack, but they weren't in any hurry as they went overseas on a massive trip. They only just got back the other day..
Sample pics are here: http://www.sidd-rishi.com/gallery/Anna%20+%20Atle/Reception/
Hope you like it :)
HOLY CRAP SIDD!! Those are freaking amazing man!
  • Replies 129
They're a bit small to really appreciate.. (or am I missing something?)
Yeah theyre small there but i saw bigger photos somewhere
cant find them :cheers:
sorry
edit:
wait
click view and vote!
Edited by Passive
Sorry dude totally missed this comment. Thank you so much!! Im very happy with my first ever proper wedding shoot. The client loves them so makes me even more happier!!
Cheers mate :thumbsup:
Facebook Photo page l My Website l Redbubble
A selection of shots from this weekends Model Shoot.
Very nice.. Love some of those natural shots :D
Lovely Laurena and Lovely models...
Oh dude loving some of those colours!! Love it :)
Pics from Clipsal on the weekend.....only a few of them tho took nearly 2000 pics over the entire weekend
ill put some more pics up soon of the SAGE Ute....
Nice work there.. Was it hard putting your camera thru the fence??
didnt put my camera through the fence, there is no way the general public can even get that close. however, because i was working for gary baxter, who drives in the v8 utes, i was able to get in the corporate box...however i had to stand on a chair to get over the fence lol
here are some more pics taken over the weekend....
one of my other favourites taken on sunday:
NA_Goodness - Cheers dude :cool: Appriceate it.
Re-did the processing as i think i went overboard with the skin processing.. so turned it down now:
I have a calibrated monitor, so if colours look off it may be your screen.
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
