Stalling issue has been present since I purchased the car. Only stalls when I am changing gear and the revs are allowed to drop. It's doesn't happen every time and changing gear really quick is my current work around.
Car also started having an irregular idle bouncing around with out any throttle.
I had seen this before on my old r32 so I figured it was simply the acc valve.
My AFM also would occasionally cut out since i replaced the turbo. Figured removing the AFM had knocked it around and cause dry solder joints.
Soldered the AFM, removed ACC valve and emptied a heap of carbie cleaner on it.
Erratic idle problem fixed and no more afm cut out but the stalling issue is still there.
Before anyone asks i used to have an external venting BOV but it was removed during my turbo installed and am currently not running any BOV.
Any ideas on what is going on?
https://www.sau.com.au/forums/topic/310326-stalling-r33/
Stall was also happening when there was a venting BOV. I have a stock BOV laying round i might get a fitting welded to my intake pipe and hook her up.
I dont think this will fix the problem but i have been told by hypergear to put a bov on my car
https://www.sau.com.au/forums/topic/310326-stalling-r33/#findComment-5112625
I suffered this problem for months... It was fixed after a service although I hadn't told the mechanic about the issue... the only non standard thing he did was clean the throttlebody, but since then I've had no such issues. He said it was filthy & clogged. Also noted a slight increase in lower end responsiveness from that service. Worth consideration I suppose...
https://www.sau.com.au/forums/topic/310326-stalling-r33/#findComment-5112702
No BOV and Atmo BOV. Same end result. The measurements from the AFM will be buggered up causing the stalling. (as it does in soooooo many skylines with altered BOV setups.
Plumb in a stocko BOV in the factory location with return pipe running between the afm and turbo inlet and see if that solves your problems before you go hunting too hard for unknowns.
https://www.sau.com.au/forums/topic/310326-stalling-r33/#findComment-5113261
I had this problem with a cracked vacuum line.. Mine was obvious as the vacuum line from the back of the plenum to the stock boost gauge had cracked on the end and thus was no longer connected to the plenum.
So yeah, check vacuum lines if you haven't already..
https://www.sau.com.au/forums/topic/310326-stalling-r33/#findComment-5113368
I had this problem with few R33s I imported years back. This was from Timing belt. Replace your timing belt and adjust engine timing to 10 degrees at idle. Normally this problem goes away.
Also check your idle controller plus vacuum leaks specially the small rubber nipple comes out on the driver side.
https://www.sau.com.au/forums/topic/310326-stalling-r33/#findComment-5113491
  • 1 month later...
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
