Hey guys
I'm in the market to purchase a boost controller
there were so many to pick from :)
apexi greddy hks hdi turbosmart and a million and one others
Who uses what and who would remcomend one over another!!
•Put down what motor your using
•quick mods- high flow turbo, injectors etc
•psi your running
•and of course why you think yours in better :)
cheers!
https://www.sau.com.au/forums/topic/310356-boostin/
Turbosmart Boost Tee, set it up inside your engine bay so you cant touch it without pulling over and popping your bonnet. Had a friend run through 3 engines because he had it in cabin and could just wind it up at any time.
Given it was a Turbo Holden V6 but still...3 engines gone.
https://www.sau.com.au/forums/topic/310356-boostin/#findComment-5113257
+1 for turbotech manual boost controller.. never had a spike in both my RB20 and RB25.. all other electric boost controllers spiked like crazy.. turbotech uses the Spring and ball.. no bleeding of the air!
iv alwaysed used them in my drift cars there awsome. set your boost and never touch it again!
https://www.sau.com.au/forums/topic/310356-boostin/#findComment-5113265
stock turbo you cant go past the turbotech. a spike in the midrange isnt gonna hurt the turbo, all that matters if that your boost up around 6-7000rpm isnt much more than 12psi
if you have a bigger turbo i'd recommend a profec b II, they seam a bit shitty at first and not so great to use but its very good at controlling boost
https://www.sau.com.au/forums/topic/310356-boostin/#findComment-5113304
you could just replace the wastegate actuator with an aftermarket one and run constant higher boost if that's all you want to achieve. much safer, and undefectable.
i mean, who are we kidding, you're gonna wind up the boost, get it tuned to that boost level to make max power, and then forget about it until you get pulled over and dicked for having a boost controller that's bright pink or whatever lebo colours they come in these days.
https://www.sau.com.au/forums/topic/310356-boostin/#findComment-5113317
I herd it's dangerous to run a manual boost tee as for boost spike :down:
Well gossip in the tea room never helped anyone.
I ran had around 10psi bleeding through a manual valve, 370rwkw/24psi... there is no issue if correctly done. That is a fact.
IMO you probably don't even need one.
https://www.sau.com.au/forums/topic/310356-boostin/#findComment-5113586
    • Hi    have purchased pair of eibach wheel spacer as I couldn’t fit set of wheels I bought for my car due to it catching caliper.   I know I need to cut the bolts on my discs so they sit flush with the nut supplied but the nut doesn’t sit all the way into the groove meaning wheel would not directly fit onto the spacer rather the nuts. Any thoughts?   See pic   https://ibb.co/VJK5w5G
    • Nah. There's not shit tonnes of pressure in there. Just drill with a 1.5mm drill or something equally tiny. When the drill goes all the way through thee gas will start to come out, but with such tiny path through the flutes of the drill bit, it won't be at all dangerous. You can be as paranoid as you like from then on. I'd just pull the drill out while keeping my face out of the line of fire. But then, I spend half my time looking into pressurised furnaces. So my risk acceptance is somewhat higher than most!
    • Been needing a new clutch for a while, but holding off because of life tingz and adulting. But... Being of Asian descent, I can't pass on a good sale, especially everyone else is selling it for $2k+ (JJR has it for $1799). Really on the fence on this one, because the unsprung version of this is $1281 via Shitbox (Sparesbox) and the sprung version is quite a bit more (no idea why Shitbox doesn't offer them). Ending up just sending it and getting the twin sprung organic. Mainly because I wanted the car to be nice to drive and didn't want to make it more of a shitbox than it already is.
    • It was the pressure I was worried about. @GTSBoy does drilling them pose any problems?
    • yep just a JIC vs ISO insulator height. old coils are for JIC, new coils are for ISO
