  • Replies 44
oil analysis? there was a thread in the last week where someone (elite I think) posted phone numbers for capital cities. if you don't want to pull the motor analysis is 100% the way to go....couple of days and you will know.
too drunk to find it myself its a bacheloring weekend for me
if its a spun big end bearing the noise gets louder as the rev's go up, the more load/rpm, the more cylinder pressure the bigger the bang.
sounds like a hammer on the crank as said before. the noise will NOT go away as rev's go up. and it WILL get worse with each time a load is put on it.
The noise of a spun big end bearing is actually a gap between the crank and bearing allowing the big end bearing to bang down each time
that cylinder fires and then slams the big end down on the crank.
  • 1 year later...
yeah I don't know why people are so afraid to spend $40 on UOA? i've been doing it for nearly 10 years on my GTRs and it tells you everything you need to know. especially if you start when the engine is still good, that way you have a solid baseline and if something starts to go wrong you know straight away. it also helps you set accurate oil change intervals etc.
For me the 'cut spark' method has never failed.
Am not sure why more people don't have the same faith.. I think it was particularly clever of the OP and thought it showed he had a decent understanding of what he was doing.
Meh.
so what would be causing a spun end bearing???
How do you avoid having one?
A done bearing is normally caused by an oil related or stress related issue. Oil related would mean it was starved of oil or was poorly serviced.Stress related is not as simple as it sounds.. It does not mean ringing the neck out of the motor, it more so means stress directly on the bearing itself. That could be caused by ping/detonation, piston contact with valves (rarer case but something not to be missed if you do have a piston meet a valve) or abuse. By abuse, I particular mean starting the motor and giving it too much stick before its at operating temperature.
A brief summary of my experiences... I have never owned a motor that blew anything more than a head gasket. I have never owned a motor for less than 40,000km and I have never owned a motor that did not see its redline daily nor for less time than it sat idle at the lights. I NEVER give my car any sort of 'stick' within the first 5 to 10 minutes of driving. My last 2 cars were thrashed the most, both of them are still running with the new owners and both have high KMs on the factory bottom ends.
Every friend or acquaintance I know who has thrashed their car from start up, has had it bite them in the bum sooner or later. We are currently repairing my own brothers 911 motor at a cost of over 20 grand due to his sheer lack of care for my advice.
Turn the key and drive it unreasonably before its truly at a reasonable operating temp and you WILL run into problems sooner or later. My brother thought he could get away with it because he always owned newer cars, now either hes owned this car long enough, the previous owner also did the same thing, or hes just simply got the kind of motor that couldn't take that kind of abuse for that long, but I'm sure he will remember the debt.
Is it possible to repair the big end bearings without removing the head? for eg, engine out..put on stand..flip the motor upside down to work on it???
Provided that the only damage done is to the bearing itself, then yes. It really depends how much damage has been done.. Sometimes you will have a bearing look like its lost its first layer or two when it makes the noise, others will start to knock and utterly destroy themselves soon after. What that means is, the bearing does not evaporate to the magical land or none.. It will grind away into metalic dust and contaminate your oil.. Your oil, being the life blood of the engine, will carry the said contaminants throughout the motor and will possibly damage other aspects of it in the long run.
Is glittery oil normal after a fresh engine rebuild. I just rebuilt my motor and im hearing a noise as weel from cylinders 5 and 6. Sounds like more of a top end noise with the stethescope but im curious about the glittery oil during the break in period. Looks like a goldish color.....
Sorry but that is almost certainly not OK. If someone else built the engine, talk to them before you start it again.
If you built it...I guess you can start with oil analysis but 99% you are going to have to pull it out.
How is the oil pressure?
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
