As for Bendix brake pads, what's the part numbers for your 33s'? Is DB1170 or DB165?
According to Repco's book, R33's pad is DB165 ( or something like that ) but my car is also R33 yet that don't fit and DB1170 fit.
Also does your capliper say something like sumitomo R 1 on it?
Thanks :D
I don't know the part number but if you have the sumitomo calipers then it is the same pad as for the s14/15 200sx. They use a cast iron version of the sumitomo. As these cars are sold locally you sholdn't have a problem getting them.
All the sumitomos that i have seen use the same pad, r32 gtst/gtr/gtr vspec1, r33 gts25t, z32, s14/15. dunno about r34 though.
Hope that helps some if you can't find a part number
Hey West,
Your probably thinking of DB1165, which is usually listed as an Aussie R31 pad, but that is the wrong p/n for even that!
DB1170 is for the front of R33 GTS_t. Not sure what it is for a non-turbo.
BTW DB1220 is for the rear of R33 GTS_t if you need them some time soon.
From memory, I think my calipers had sumitomo stamped on them as well!
Hope it helps.
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
