  • Replies 45
yeh I wouldn't think it would make that much more even if boost remained constant through out the rev range...
I'm seriously considering E85... going to have to look into bigger injectors and fuel setup... but might just wait till I see some more digits in the savings account :laugh:
thanks
nope.. motor is unopened besides the Injectors
Mods are the generic mods..
PFC
Profec B
550cc injectors
Full 3" Exhaust...
custom dump
custom intake
apexi pod
BOV
z32 AFM
walbro pump
etc
Nice power....
But I thought z32 AFM cant read anything after 260rwkw? And how much psi were u running to get that sort of power?
Nice power....
as per the dyno sheet attached on the first page of this thread, roughly 18-19psi fading down to about 17psi near redline.
.... GCG rekon this new rear housing is 'original' Garrett and much more efficient...
I would say this is the key ingredient for the better output you have now and is typical power for both the original Garrett Gt3071 with the .82 rear end and the Hks Gt2835..... with the extra 10kw or so just being difference in dynos
I thought and so have read, that the stock head gasket needed replacing when boosting over 1 bar or so?
and where have you read that? I smash 1.3bar into my motor day in and out, and it's unopened.
    • Yep it is overflowing. All was working fine but been off for a year so guess something may have seized. Steering is heavy yes   i will raise the front of the car and will turn side to side to test id bubble goes away
    • Does the steering feel heavy when you turn the wheels? Any puddles of fluid on the floor or that you can see leaking from anywhere? You could try bleeding the system, if it’s making a whining sound when turning the wheels then that’s a sure indication there’s air in there somewhere. Start the car and remove the reservoir cap, then turn the wheels from left to right a few cycles and then check if you see any air bubbles rising to the top of the reservoir. Top up if necessary and repeat. Otherwise, I can only suggest that your pump vanes have seized or that there is a perished seal somewhere??
    • No idea. It's too weird.
    • The jack holds itself in place. You slip it down into the receptacle and give the input a twist to open it up a little and jam itself in there.
