  • Replies 45
Posted Images
this motor is completely standard... and has been running 18-20 psi for the last year or so.... It hasnt complained at all. That also has a lot to do with the fact that I dont put my foot to the floor everytime i want to go somewhere.
Also depends on how you treat yr motor... I have a mate destroyed his standard turbo AND engine simply by the way he drove... blardi lunatic
this is the T3 flange.... is suppose to bold directly onto standard skyline dump/exhaust
I had a custom dump made because I bought my old GT3071R came and the dude threw in his dump pipe and when I went to bolt the new turbo on, the flanges on them were different... so the tuner got some welder bloke in and work his magic
Tuner rekons the new dump has made a huge difference in terms of flow and performance...
wasnt cheap tho haha
Edited by usmair
