Ok, I have purchased a second hand pair of r33 gtr front driveshafts and would like to get them reconditioned before i fit them.
I have used a driveshaft mob in hawthorn many times before and do not want to use them as they are very hit and miss.. they get it right sometimes but other times they dont and i really only want to do the job once.
can anyone recommend a place in melbourne... i have looked on yellow pages and there are plenty:
Driveshaft Joints in Melbourne
cheers.
https://www.sau.com.au/forums/topic/310418-driveshaft-mobs-in-melb/
cheers.
+ 1 for
Hardy Spicer
U1/73 Remington Drive
Dandenong South Victoria, 3175
Telephone: (03) 9799 3250
Made up a great strengthened drive shaft for my brothers commodore after he broke his in half, pretty cheap for the quality and they got the work done in less than 24 hours too which was pretty sweet.
Edited by FrangaR33
I (and alot of other zed guys) have used Knox Driveshaft services with no issues to date.
73 Bursaria Avenue Ferntree Gully, 9758 4015. His name is Jeff, give him a call and he'll help you out. You might have to drop by his workshop to show him what you want done. His prices are good and I can't fault his workmanship.
yeah i've been using jeff for years.. i actually went and saw him the other day if he could help me out but he doesn't really do FWD driveshafts.. he said he'd reco them if i organise the parts, which i was considering but nissan dont sell any parts for driveshafts so all the gear will essentially be aftermarket - its an option if i coudl source all the gear but i rather take them to a reputable place that can do the job start to finish.
any others people?
get some drive shafts done at this joint at the moment will tell you on Wednesday wat the are like
Hardy Spicer
only thing is i have an r32 gtr and they would not touch the front shaft !!!!! :mad:
Hardy Spicer
they wouldn't touch the front shaft b/w the transfer case and front diff or the front driveshafts themselves? cheers mate.
If you're looking for Northern suburbs, I found these guys really good:
Duggan's Balancing
50 Newlands Rd
Reservoir
Vic 3073
(03) 9469 4550
They built and balanced a custom shaft for me for a turbo 400 box into my truck
  • 6 years later...
Digging up an old thread, I'm looking for a driveline specialist in Melbourne.
I've always had some slack/backlash in the driveline since the manual conversion (all correct R34 parts), it 'clunks' when changing from 1st to 2nd especially.
I wouldn't mind working out whether it's the clutch/flywheel, box itself, driveshaft balance/centre bearing, or the diff.
Also looking at getting the following done:
  • Engine rear main seal
  • Input shaft seal and gasket
  • Output shaft seal
  • Spigot bush – if needed
  • Driveshaft rebalance – if needed
  • Gearbox mount
Any recommendations in inner Melbourne or the north?
    • 65601-05U00 is the hood latch. 62550-08U31 is the support that holds it to the radiator core support. They are all super discontinued so I don't really have any great leads on how to source this stuff.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
