Hi All,
As the topic suggests which shocks are softer (ie nicer for the street) on the rear of a 34 gt-t skyline:
Bilstein Rear Shocks (non adjustable) part number B46-2108
Koni Sport Rear Shocks (non adjustable) part number 8040-1226Sport
If anyone has any experiences with these that would be fantastic.
I want the softest good suspension for a 350mm wheel to arch height on the rear of my R34 GT-T.
Shock absorbers do not have a stiffness rating, it is very complex. If anyone has any experience with them it would help a lot.
Just got a quote for the koni's and it was $504. Not bad.
Unique Autosport has the bilsteins for $690!
You should be able to get the Bilsteins at Repco for under $300 each :D
And I'd pick the bilsteins over the Koni's. Not because they're 'softer' but they'll suit a wider range of spring rates and perform very well for the money (I run them in mine).
Few dilemmas!
I had another look at the koni listings for the R34 and they only have one part number. There should be 2 part numbers, one for the GT-T and one for the n/a GT. It is the same part number for the rear R33 GTS-T shocks, meaning that the R34 part number will only fit the n/a GT R34 model.
Grrr
Plus there is no bilstein part number for the R34 skyline at all!!
I just want some good shocks for an R34 GT-T.
Only ones I can find that are specified for the R34 GT-T are kyb:
http://cgi.ebay.com.au/Nissan-Skyline-R34-...=item5190e8127c
Edited by Harey
Bummer!!! Geeze this shock thing is annoying the crap out of me!!
Koni only have a part number with eyelets at the bottom!!!
There is no bilstein part number for them, so you have to get them custom made.
Surely someone sells an off the shelf shock absorber for the R34 GT-T!!
How similar is the R34 rear end to an S14/S15? Presumably it has the fork bottom, but apart from that are the dimensions the same? If so, check nissanroadracing.com and see what the guys that run S14s are using on their cars after they do the Z32 rear upright conversion.
Also, try phoning Bilstein Australia? They should be able to give you info on the Bilsteins they recommend for R34s.
Edited by mattah
The R33 GTR rear shocks are the same fittings, the only difference is they are phsically longer. Guy in another thread said he fitted some R33 GTR rear coilovers to his R34 GTT but they couldnt get them low enough to be a good height.
Yeah thats my next thought. Its just I dont like the idea of custom shocks both price and delay.
Its strange all these shock sellers have neglected the R34 GT-T.
Edited by Harey
Ok phoned Heasmans Suspension (Australian Distributors of Bilstein) and they have some of the shocks left from Sydney Kid's Group Buy although they are back to full price. They quoted me $660 for a pair of Bilstein rear shocks for an R34 GTT, plus $44 for the height adjustment option. I have ordered these.
Also I spoke to a high up person in Koni and they say to use the R34 GTR part number which is 8041-1339Sport. Yes they have the right fittings but I thought they were physically longer. Theres another thread on here with a guy who fitted GTR coilovers to his R34 GTT and they couldnt get the car low enough.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
