Compaq Presario CQ61-107TU Notebook PC (NW982PA)
Brand spanking new in box, opened to check contents but laptop still in sealed plastic. Ill let it go for $600, FIRM.
Specifications can be found here. http://h10025.www1.hp.com/ewfrf/wc/documen...=reg_R1002_USEN
PM me or email: [email protected]
Compaq has released a new version of this laptop recently, pretty much same hardware/software. Both running Vista premium. new model is CQ61-214TU, rrp $999. asking price dropped accordingly.
https://www.sau.com.au/forums/topic/310482-compaq-presario-laptop/
    • Depends how low and tyre size. Should fit with natural camber, skinny tyres and rolled guards.
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
