hey guys i have a 93 rb20det r32 with ecu and big turbo etc etc and i was just wondering if there was any way to perform a cheap cam upgrade???i dont really like the idea or reprofiling cams ... but ive heard that n/a rb20de cams should give an increase??? and another thing i was wondering is would rb26 cams and solid lifters fit or something along those lines...im gonna make some adjustable cam gears and do the timing belt while im at it if it doesnt already have cam gears lol.... anyone got any ideas???
https://www.sau.com.au/forums/topic/31050-cheap-and-easy-to-find-cam-upgrades/
actually i read somewhere about putting NA cams into the turbo engine but i'm not sure if it was true... i think it also said the intake cam was the same but exhaust cam was different.
this could be the ideal low-cost upgrade for you if it works...
RB20DE inlet has a smaller duration and less lift than the DET, ie 232deg and 7.3mm lift vs 240 and 7.8deg lift. (edit: ie, not likely to get gains there)
Exhaust cams are the same EXCEPT, the lobe centre angles are different (as they are for inlet too).
These specs from the Tomei cam spec sheet on their website :http://www.tomei-p.co.jp/_2003web-catalogu...haft-specs.html
I would hazard a guess that you would get gains from adj cam gears, this is based on gains from using them with RB25, so not really conclusive.
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
