today whilst idling the car on a slight lateral angle , the car just died and engine turned off. wouldnt start again intially but after a 1min or so it turned over again and started. about 3 mins later when slowing down to park again the engine cut out again just before parking. This time i got the japanese oboard computer lady announce something that sounded important!
Any ideas?
Any ideas?
A common fault (was actually factory recall) was on the crank angle sensor.
When it fails the motor will just turn off randomly (not fun at 60kmh) and will generally restart after stopping or if you can get the car back to N to restart.
You should be getting a Check engine light. Try doing the sequence to get the diagnostic codes.
This happened to my M35 and I have heard of it on the V35 also. It also affected Australian delivered Pulsars of the time as they use the same part.
Hope this helps.
Cheers
Andy
Ive booked it into the nissan dealer here in christchurch, nz so hopefully they can get the right diagnositcs out of it. Will let you know what it costs, thankfully i have mechanical insurance!
Hope this helps.
Cheers
Andy
It happened to me again last night, driving and lost power, to the point where it almost died but i pulled over and it keep idling quite happily. however this time after i turned off the ignition and restarted the engine (took a while to turn over) i had an engine check light on, and the VDC off and SLIP lights were on, even though i had not turned VDC off. Pressing the button made no difference, almost as though the onboard computer had disabled VDC for some reason. I managed to get back home ok, then this morning started the car and the VDC had returned to normal, but the engine check light remains.......
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
