Ok today was suposed to be a good day, i got all my parts i was missing and i started cranking on the motor nice and early, but about an hour into it while torqueing one of the bolts to the rear main seal it snaps effortlessly. ok no big dead i have extracted tons of bolts, so i drill it out perfectly center and procede to use my extractor which than snaps in the bolt which is inside the block. i tried almost every bit known to man and nothing grabs it,, i bought a super expensive industrial bolt out but i cannot not drill into the old bolt out. the snap is flush with the block so i cannot try to grip it and take it out. my ONLY option is to drill and extract. does anyone know a good drill bit that i can use to get this out. i am soo f***ing mad i thought i was gunna slam motor on the hood of the chassis in a fit of rage. has this happened to anyone else ? i know better than to ask this, but has anyone else only used 5 of the 6 bolts that hold the seal in place. I am pretty sure only using 5 bolts would not be too bad. i looked at it and it dosent hold see any physical stress, and its rtv sealed. any input. after i messed around with it, i am sure it can onlybe extracted by a machine shop....
https://www.sau.com.au/forums/topic/310574-broken-stud-on-rear-main-seal/
good work breaking that one! I've seen plenty of main rear seal bolts stripped but normally the ones from the sump where they thread into the alloy rear seal housing. Anyway I'd probably leave it, if it leaks like a bastard some how (unlikely) you can always take the flywheel off and get to it in the car
I guess you weren't using a torque wrench...these are only m6 bolts right?
USA - do you have spark erosion guys over there? They seem to be able to get the impossible studs out..............not sure about ezi outs though, they are tough metal?
Otherwise a Dremel with some tungsten bits and be prepared to break a few, it won't be easy thats for sure.
Carbon tipped drill piece for drilling stainless, BUT you HAVE to drill freaking slowly (Like slowest speed possible!) or you will munt the drill bit.
Carbon tipped drill pieces are used on stainless and other very hard metals.
high speed dentst drill and a carbide bit or hers one for you weld a nut the same diameter as the origonal bolt head onto the shank,the nut will almost shutter the weld pool so it doesent contact the rest of the casting,ive done this many times before
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
