Hey guys,
Me and my mate have been working on our rb30det dedicated drag cefiro....all the engine work is pretty much half completed, just bolting all the outside stuff on etc to go,
But me and my mate had a cool thought ( and is more likely to be a stupid one!)....what if we had a custom top mount manifold that stuck the turbo high out of the bonnet so it always gets cold air...not bothering with any cold air intakes/boxs etc and we were already going to buy an expensive manifold so we dont get cracks later on down the road,
But would having a turbo sticking out of the bonnet such as a gt30/40...would the on coming air while your driving cause it to lag because the air rushing at it can slow down the turbine? or would it not affect it? or would it run any better having cold air going through and more air? (even tho i know its more for looks then anything :D )
Iv seen some proper decked out drag cars that do the same with their turbos...but there expensive engines and the turbo is probly on boost from the very beginning,
Any thourghts would help! thanks guys
https://www.sau.com.au/forums/topic/310630-turbo-sticking-out-of-the-bonnet/
  • Replies 45
Yea i get that big drag cars mainly do it because of the size of the turbo is too big to be stuffed anywhere....but does it provide any negative performance gains or any positive ones? thats mainly what i want to know
PERFORMANCE GAINS MAN WHO CARES YOU WOULD LOOK SO FULLEEEEEEE SIIIIIIIIICK!!!!!!
no gains, nada none. not until you were doing 200+km/h - below those speeds you would just appear to be the wanker that you are.
Good luck if it is raining hard.
How often you seen WSID lit up when it's raining?
I think that whole "nothing good to say, say nothing at all." thing may apply here.
Why wouldn't it work until 200? Are you talking of a ram-air effect?
I don't think the plan is to get a ram-air effect, I think the plan is to get access to nice, cold, clean air.
You're a dickhead.
Gee thats being a little harsh isnt it ? Why call him a wanker for ? He did say it was for a dedicated drag car-So I am assuming it will never be street driven.I guess it would make working on the car a LOT easier.Shorter piping as well. I would be making up some kind of fibreglass RAM air intake feeding directly into it....
I reckon you've just outed yourself as a dickhead.
I don't think the OP is wanting a ram-effect, I think rather he is chasing nice cold, clean air.
Turbulence around turbo charger intakes allmost allways affects power in a negative way. I'm not saying that a proper cold air setup doesn't help but you need to let the turbo to draw the air in and align the air with the impeller. You could just put a pod on the the intlet of the turbo.
there was a bit of this going on at Powercruise- anyone that was there would have noticed the green Torrie with the rego 'SUBTLE' that had two huge turbos almost completely out of the bonnet...
plenty of top-end drag cars these days have the turbo just high enough so the inducer sits level with the bonnet, with the bonnet shaped as a guide near the bottom of the inlet. freshest air possible with no vacuum losses, but not great for engine life. sucking in a dragon-fly or some other big insect prolly wouldn't do the turbo much good, either
Cant really see drag car guys even the top end guys testing the effectivness its effectiveness.
I would definitely look into doing it for a dedicated drag car. As stated maybe run a pod filter on it to minimise turbulence around the inlet to the turbo & to stop sucking crap in. Have seen full-race (unlimited budget) drag cars with the bonnet shaped to act as a sort of scoop to help feed air into the turbo...
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
