Hey guys,
Me and my mate have been working on our rb30det dedicated drag cefiro....all the engine work is pretty much half completed, just bolting all the outside stuff on etc to go,
But me and my mate had a cool thought ( and is more likely to be a stupid one!)....what if we had a custom top mount manifold that stuck the turbo high out of the bonnet so it always gets cold air...not bothering with any cold air intakes/boxs etc and we were already going to buy an expensive manifold so we dont get cracks later on down the road,
But would having a turbo sticking out of the bonnet such as a gt30/40...would the on coming air while your driving cause it to lag because the air rushing at it can slow down the turbine? or would it not affect it? or would it run any better having cold air going through and more air? (even tho i know its more for looks then anything :D )
Iv seen some proper decked out drag cars that do the same with their turbos...but there expensive engines and the turbo is probly on boost from the very beginning,
Any thourghts would help! thanks guys
https://www.sau.com.au/forums/topic/310630-turbo-sticking-out-of-the-bonnet/
  • Replies 45
Yea i get that big drag cars mainly do it because of the size of the turbo is too big to be stuffed anywhere....but does it provide any negative performance gains or any positive ones? thats mainly what i want to know
PERFORMANCE GAINS MAN WHO CARES YOU WOULD LOOK SO FULLEEEEEEE SIIIIIIIIICK!!!!!!
no gains, nada none. not until you were doing 200+km/h - below those speeds you would just appear to be the wanker that you are.
Good luck if it is raining hard.
How often you seen WSID lit up when it's raining?
I think that whole "nothing good to say, say nothing at all." thing may apply here.
Why wouldn't it work until 200? Are you talking of a ram-air effect?
I don't think the plan is to get a ram-air effect, I think the plan is to get access to nice, cold, clean air.
You're a dickhead.
Gee thats being a little harsh isnt it ? Why call him a wanker for ? He did say it was for a dedicated drag car-So I am assuming it will never be street driven.I guess it would make working on the car a LOT easier.Shorter piping as well. I would be making up some kind of fibreglass RAM air intake feeding directly into it....
I reckon you've just outed yourself as a dickhead.
I don't think the OP is wanting a ram-effect, I think rather he is chasing nice cold, clean air.
Turbulence around turbo charger intakes allmost allways affects power in a negative way. I'm not saying that a proper cold air setup doesn't help but you need to let the turbo to draw the air in and align the air with the impeller. You could just put a pod on the the intlet of the turbo.
there was a bit of this going on at Powercruise- anyone that was there would have noticed the green Torrie with the rego 'SUBTLE' that had two huge turbos almost completely out of the bonnet...
plenty of top-end drag cars these days have the turbo just high enough so the inducer sits level with the bonnet, with the bonnet shaped as a guide near the bottom of the inlet. freshest air possible with no vacuum losses, but not great for engine life. sucking in a dragon-fly or some other big insect prolly wouldn't do the turbo much good, either
Cant really see drag car guys even the top end guys testing the effectivness its effectiveness.
I would definitely look into doing it for a dedicated drag car. As stated maybe run a pod filter on it to minimise turbulence around the inlet to the turbo & to stop sucking crap in. Have seen full-race (unlimited budget) drag cars with the bonnet shaped to act as a sort of scoop to help feed air into the turbo...
    • have no doubt and wanted too trust me and may regret later not necessarily worried about weight (would be 8 kg ish total) it was more the $$ to do it properly is about $6 - $7K in hardwear need long 310mm stroke jacks etc - plus install and call me whatever im not doing it myself even if wanted too cant weld etc  - thats $10K installed vs fraction of that cost while Ive spent some money on this POS I actually really dont like doing so unless its got a large chance to make me go faster 😁 hey in still carting this things around on a 15 yr old rusted open trailer so I can spend on racing not buy a new trailer to look better the manual jacks Ive had done are heavy and take space but are transportable and usable anywhere - taking or organizing even compressed air let alone nitrogen which is more whats needed coming from Perth to Winton or Sydney or the like honestly just adds to my brain headaches/ hurts of organisation also ha 15 mins job will get down to 2 - 5 min job vs 1 min job for airjacks - all tradeoffs I spose
    • Purely out of curiosity, how do you know all this @dbm7? Do you work with automatic gearboxes professionally? This goes way way way beyond "I've had an automatic Skyline once and did some mucking around"
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
    • Maximum Attack has entered the chat
