All the information is usefull.... but its a deregistered cefiro that me and my mate have got...its not going to be chasing the fastest of times at the strip...its a car that me and him can take to the friday night drags and have some fun...becuase it cant exactly get street legal here in NZ.
I just wanted to do somthing that "i" thought would be cool...but was wondering about the performance etc because i still want a fast car!
and about the gt3040....its the turbo i have sitting in my shed...i dont have a couple of grand to spend on a new one...but the gt3040 can still get the job done. that brumby is pretty much what i was going for but just wanted some advice
cheers
  • Replies 45
Sup ,
I think it would give the car character :laugh: and also raise the chances of blowing a comp wheel from someshit getting stuk in it lmaoooo
(BITCH TIME)
Im also slowly starting to get sick of idiots giving shit to people who are "modifying" their cars.. mostly these people giving shit because they cant afford to do it them selves but honestly ... its becoming a joke u cant post anything on this forum with respect to doing some fun mods without being hounded by 50 year old jaguar enthusiasts who are STRICT on keeping their car FACTORY because all the smart engineers built the cars that way for a reason!!! ITS HIGH FOR A REASON ITS GOT BODY ROLL FOR A REASON BLA BLA BLA PUT SOME BLODDY COILOVERS ON IT N SHUT UR MOUTH sorry im just angry lol venting...etc.. what im saying is.. MOST of Nissans profits are from the modification aspect to their performance cars.. reason they dont put fkn heavyduty clutches in their cars.. COZ THEY KNOW they gona be profiting from all the clutch manufactures making HD clutches for their cars... hence u drop a patch and u need a new clutch... woah massive bitch ok im over it...
(BITCH OVER)
night boys :mad:
Couldn't agree more. If humans never considered a few dumb/off-centre/left-field ideas, where would we be? Good on him for thinking about something. Leave the boy alone!
(and so WHAT if someone wants to do something for looks. Looks is okay.)
(BITCH OVER)
night boys :mad:
No disrespect but you think Nissan make money on companies like Exedy, HKS, Blitz etc making clutches on their cars? You honestly think Nissan don't do something to a car because there plan is the car will be modified and some how they will make "MOST" of thier profits this way? So Nissan didn't put a $3000 triple plate carbon clutch into your R32 GTS4 not beacuse it would make no sense to do so on a car rated at 140kw, but because they knew you would modify it, go out and buy a super expensive 800HP clutch and this in turn would make them money?
I think you need to do a bit more research on the construction/engineering aspect of designing something.
Edited by PM-R33
R.I.P.S in NZ have built an r34 drag car with the turbo half sticking out of the bonnet and have a duct that goes directly to the turbo inlet, you can see the turbo, its like right there spinning away... These guys have built a fair few cars and mostly drag, so they might know what they are doing...
i got a spare fibreglass bonnet which i will be cutting into, and making like a ramp piece to guide air down to the inlet. its not my daily bonnet so just something to do at the drags.
Instead of running a pod, the other option like i have seen fairly often is a strong mesh cover over the inlet so it will stop most large-ish things getting in.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
