Replaced Turbo, Now Sluggish
Blew the exhaust wheel on my stock r33 gtst turbo a few weeks back, removed it myself and sent it away to hypergear for a highflow. Got it back and re installed it myself and now something just isnt right.
Car is really sluggish, like 5psi by 4000rpm sluggish, then really struggles to build beyond that, but will quickly after about 5500rpm .Boost wont hold at all and I've tried two new waste gate actuators, using the same air line I've always used plumbed straight into the actuator. Its getting up towards 15psi by 6000rpm, but defiantly doesn't feel like 15psi should, even accounting for R&R.
Other things I've noticed is the stock BOV seems to have gotten louder, and you can hear the turbo spooling whilst the car is still in vacuum according to the boost guage, which has read correct up until now.
I've checked for something obvious like a loose hose i didn't tighten properly, but to me it all seems the way it was before.
Mods are:
FMIC
3" exhaust
Any ideas on what my problem is, or where and how to go about starting fault finding?
Any help appreciated :D
Is it ball bearing or plane bearing?? Plane bearing turbos usually need a bit of a run-in (about 100km). Mine used to take a while to before it began to build boost but now it feels fine.
You may also want to enlarge the oil feed to the turbo as plane bearings require more oil than stock and ball bearing turbos.
Regarding the louder sounding BOV - this would be due to the extra volume of air that the turbo is forcing through your intake. More air is being released when you throttle off, resulting in a louder sound.
EDIT - Try lowering the boost from 15psi. You may find this will feel better as the ECU doesn't compensate much above 12psi...
Edited by EeLeYe
Im using the 7-9psi one atm, was using the 15psi proir to that. Im the guy you posted one to yesterday to swap.
The way its running, its more like something isnt connected properly or ive forgotten to connect something, loose piping or something. It doesn't feel as if the turbo itself is at fault, the car just seems generally rough, where prior it ran like new.
A mate did suggest the O2 sensor as it could have been damaged when the ceramic wheel blew itself off down the dump. Could this cause these symptoms?
The oil feed was enlarged, and supplied by hypergear. Im not trying to run 15psi, its spiking there. Most of rev range its spooling from about 2500rpm-4000rpm to about 5psi, then after that it really struggles and stutters to build more boost. Its pretty much taking 1500 rpm to build 5psi of boost.
As for a tune, i plan on getting one, but once it is behaving reasonable.
Edited by Sparky206
mm.. interesting. Did you stick the BOV and breather plumbing back into the intake pipe? any leaks after the AFM? Also after fitting the new actuator you need to adjust the rod to make sure the wastegate is in a tight shut position.
Cleaned out the cat while the turbo was out and removed all the fragments of my exhaust wheel, although i never did find the shaft that snapped off....
BOV plumping is all connected, checked it a few times and all seems fine, will check for leaks after AFM tomorrow, but im doubting it.
Wastegate was adjusted so it has some pre-load, adjusted it so that with both closed half the hole overlapped the pin, then pulled on the rod and slid it over the pin and cir-clipped it in place
by any chance, did you find the ceramic wheel in the cat?
if so, im sure u pulled it out, but did you consider it could have caused your cat to collapse? or if tis a metal one, might have mangled it.
look into it, or let us kno wat u hav done in regards to this.
Yes i found the wheel in the cat, in about 5000 pieces. I removed it all.
As far as i could tell, cat looked un-damaged, just looked like a spiral of radiator fins, none were mangled or showed any signs of an impact.
Looking down the dump you could clearly see where the wheel had impacted at the bottom of the dump, there was a large stain of ceramic dust followed by lots of little mounds of ceramic up the rest of the dump towards the cat. I would be fairly positive that the wheel was in many pieces by the time it arrived at the cat
did the engine ingest fragments of the turbo ex wheel? what happend when the turbo blew,did you back off the throttle or keep it nailed?
it can't injest it from the exhaust side no.
its doubtful this would have any bearing on the issue in this case
did you loose anything on the compressor side? i.e. from the bearings shitting themselves?
maybe a bit of compressor wheel has damaged a cylinder and youve lost some compression in affected cylinders?
+1 for taking off the exhaust from the cat, give that a boost around and see what that does.
other than that, maybe have a look at your MAF, it might be reading wrong cos its damaged (from said compressor fins), and its not reading your engine is under load which is causing only 5psi.
good luck! this ones a mystery!
There is a small nipple on top of the BOV which is connected to vacuum source made to press the BOV piston down under load. Please check to make sure that is connected and the vacuum source is after the throttle body.
Or boost pressure will force open the valve after few psi and create a boost leak.
+1 for me on this...
You have 4 things that suggest it is something to with a boost leak past BOV..
1. BOV sounds louder than what it previously did.
2. Turbo spooling can be heard even when inlet manifold pressure is in vacuum.
3. When boost starts to go +ve it is intially is very low and climbs..
4. The only way the standard ECU (I assume this is what you have) will allow the engine to run at 15psi @6000rpm and not hit airflow cut (which is different to R&R) is if some/most of the air that has gone past the afm is recirculating..ie passing through compressor, through BOV and back to the compressor, then to BOV etc etc...
Hope this makes sense...
Thanks for the reply's guys, they've been a great help in getting the mind ticking. To add another symptom, had someone tell me who saw me take off as i went for a test that the exhaust sounded like the engine had a miss in it, didn't sound smooth and healthy like usual.
As for when it happened, i had it floored and it was just coming off vacuum then nothing, probably held it there for half a second, realised something was wrong, got off it then back on it to see if it would happen again, then saw the massive cloud of oil smoke out the back and limped it the 300m home.
I too was very worried about ingesting ceramic dust, but after i took the dump off, you could follow the path of the wheel as it spiraled down the dump, then see the impact at the bottom of the dump, with many small mounds of ceramic dust pitted on the walls on the dump up until the cat. There were no signs of ceramic dust either in the dump before impact or in the exhaust housing. I must say though, the way the turbo snapped, it snapped the shaft flush off at the seals, and assuming the shaft was metal, i still haven't found it, and it certainly didn't get past the cat.
Compressor side of the turbo was undamaged. All fins were still in tact and shaft was still spinning like normal.
Just went and checked the BOV and the nipple you speak of is still connected, i didn't touch any of the hoses after the BOV. I do have the Standard ECU, and yes i have hit air cut once. Ill assume thats what happens when the car pulled all fuel and had to be restarted after it hit 15psi plus. Other times after that im backing off once i see its gone past what the wastegate is set at.
Next step over the weekend ill start checking for boost leaks around all the connections, whats the best DIY method for this without rigging up a gas bottle and pressurizing the system?
Once again thanks for the replys ;)
Edited by Sparky206
Hmmm. Maybe Its just me but the main thing that stands out to me is the ECU
The standard ECU with a modified turbo running 15psi is probably screaming out at you "What are you doing man?, I just shouldn't be breathing this hard".
I'd look at getting this new setup tuned with a power fc or equivalent. (you may even find a good tuner will be able to diagnose the problem during the tuning process). Then depending on your highflow you will probably be getting pretty close to pump and injectors as well (re tune after injectors as well).
Edited by l_uk3y
Re-read what ive been saying, Im not trying to run 15psi, if i could get it to hold even 5 psi id be happy, but i cant get it to hold any boost level, its spiking everywhere.
The car is a dog to drive atm long before it gets anywhere near 10psi
 Share
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
