Hey everyone
This is just a bit off a random question but wanted to clarify it.I have a r32 with an rb25det engine and box conversion done to it, it’s a standard rb25 s2 that went in, uses all standard parts including ecu and turbo..However it does have some light mods on the car.
Mods i have:
- Straight through exhaust
-Pod Filter
- FMIC
-R32 Gtr fuel pump (has been re wired to get constant 13.8-14v)
Until I save up for bigger turbo, injectors and a standalone ecu I thought I might as well use my Apexi ACVR, SAFCII to get a tune done so that I could have a bit more power out off it.
I got a tune done and got 250 rwhp @ 10 psi.. I asked that what was the restriction in the car was and they said the ecu wouldn’t allow for more boost as it would start spiking and also cause the fuel to run rich, then run lean, then rich and so on.. Also they stated that my power curve wouldn’t be smooth and would have no power until higher rpm.
Is this a common problem with the S2 motor/ecu? Is it due to the vct ?
Another reason why i am asking this is as my friends farther made 298 @ 13 psi with everything the same as mine except spit fire coil packs (he owns a r33 s1)
Thanks any help appreciated
Niran
Edited by niran
it's more likely due to R&R (rich and retard). as soon as the ECU detects that you've gone too far out of the normal envelope it pulls timing and dumps in fuel to save the motor.
if you're pushing 250rwkw you need a standalone ECU dude. don't waste your time continuing with the factory item. i'd be VERY surprised if anyone made 290kw on a genuine stock ECU even with a fuel fiddler intercept - gotta be remapped at least.
hey bud, nah not after kw? was talking about hp.. yer i know, wanting to go a Powerfc asap
the biggest problem with running more boost is you have to put more correction into the safc to bring the afr's back to normal, this adds more timing too so most of the time you cant put in enough correction without the motor pinging. i maxxed the stock turbo with a full power fc tune at 250rwhp, some make 270-280, some done. just the way it is. 298 might be bending the truth a bit tho
i'd say that there is a good chance that your mates 298hp car doesn't have a stock ecu. it has probably been remapped.
other than that, as people said, it is the protection built into the ecu that is causing you to hit the wall so to speak. whether you go a s1 or s2 ecu won't make a difference. either get yourself a PFC or a nistune if you want to go higher.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
