QWK32 - i have a copy of the software yes..
mods are
HKS GTR-s
front mount
3" exhaust
greddy boost controller
the guy before me had haltech on it but i saw alot of advantages to the nistune so i went that way..
i have acopy of all the base maps aswell, is there some things i can do to that to help things?
i also have a apexi turbo timer which outputs the AFR'S, as soon as you touch the accelerator at 60k's it goes from 14.5 to 10.5 or even 10.0 sometimes..
thanks again
  • Replies 41
mods are
HKS GTR-s
front mount
3" exhaust
thanks again
don't pay any attention to the apexi timer reading. the stock narrowband O2 sensor can't be trusted with any value apart from ~14.7, even then i'd doubt its accuracy. if your getting a reading in the 10's on the pen timer, it could really be a value anywhere from say 10-13.
what tune do you currently have on the ecu, stock maps? on the stock maps it will run rich once on boost even with the GT-RS. i suppose you could take a bit out of the high rpm, high load part of the fuel table, but without getting a wideband O2 sensor to check it you wouldn't know if you've taken too much out. do you have access to a wideband O2 sensor?
also i'd be interested to see if you coming close to the limits of the stock AFM, what boost are you running? link up to the ecu with the software and open the timing map, then watch the map tracer to see how close to the right hand side of the map it goes when you rev it out under load. ideally you don't want it to hit the last row of cells. also check the fuel map, it has a smaller load scale than the timing map so you can run off the edge earlier than you will on the timing map.
flippin' heck
i thought you could get Nisstune's for all Stags. i was looking forward to putting one in my S1 later this year :P
you can, but you have to be willing to chop and rewire your ecu loom to a Z32 ecu plug so you can use a Z32 ecu.
don't know if this would work, just an idea. but could you replace the stagea engine loom with a late model R33 engine loom? engines are the same so electrical plugs should be the same. probably have to splice in a few wires that go to other areas of the car, should be an issue though. then you could easily run a Z32 Nistune ecu without having to hackup, identify, and rewire the stagea loom.
i have stock maps loaded, no tune has been done since the board was fitted... don't have access to wideband.
using stock afm atm but i have a z32 ready to go (wiring is all sorted just needs to be plugged in). next part sounds like too much effort!! lol
i have no idea once it comes to the tuning side of things so yeah, i friend works at a workshop that has just signed up with nistune so i might just get them to tune it for me.
  • 1 year later...
I am trying to find. Who in sydney does nistunes and has had heaps of expirence and has a 4wd dyno
Someone has recommended CRD for tuning. And I do believe they have a 'special' offer in their business thread on these forums.
But I've never done this before so....
Unigroup.
Either get them to drop the front driveshaft or drop it yourself.
If they are happy to let it on the dyno with the little green plug pulled then you can go that way.
I would strongly suggest using them.
Unigroup.
i want unigroup to do it but i am a fusy prick and i want it done in 4wd. Unigroup know envy performance and they have a 4wd dyno and sometimes use it so i am trying to see what i can hook up.
What difference does a 4WD dyno make? Nearly 100% of the time your car peddles around on the rear wheels.
If Yavuz uses the Envy dyno it will be for cars that does allow easy 2WD mode.
Best bet is to give them a call and see what they say.
I paid extra for a 4wd dyno once but then thought why did I do that ? There is no point whatsoever fussy or not. Just drop the front driveshaft and pull the fuse and the 2wd dyno will do just as well. The only difference is you will get a rwd power figure but so what ? The tune and output is the same. You can always look out for a dyno day on a 4wd if you must have the awd figure.
...and it will be within a bees wang of being the same anyway.
not quite true.
my car dyno'd at 210rwkw with the front shaft dropped on a 2WD dyno.
on an AWD dyno it dyno'd at 178awkw - same car - same mods - same boost.
different dyno, yes, but i doubt it would account for a diffence of some 30+kw. lots of mechanical loss of power in the drivetrain. does that mean the car would go harder in 2WD mode? i have no idea.....but the dyno doesnt lie...much. heheh.
(out of interest, that was done on an eManage Ultimate. i now have a Nistune that i'll be throwing in and getting retuned. Mod's won't have changed at all, so it will be verrrrry interesting to see what figures they can pull out of the Nistune vs the Emanage)
Edited by SMOKEYC34
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
