ok ive been instructed by the people that tune my car that i need a better cat on my car ( really big and very high flowing) as the one i have now is restricting the power output.
before people start saying just gut the one i have now, NO! the car is already loud enough as it is and draws enough attention already and ive done it to a previous car and im not polishing the rear bar every single week.
ive had a little bit of a search but nothing really helped me out
im after what brands that are proven to be very effective and where can i buy them.
looking for something like a 5-6" body with 3.5-4" inlet and outlets
Thanks in advance
https://www.sau.com.au/forums/topic/310712-cat-convertors/
Chris, I'd suggest looking at something like the 5" body Catco Metal Cat.
With most of the big body cat's you will need to have them flanged to suit your current exhaust.
yeh i kinda figured that it would need to be a custom job which i dont mind. where bouts can you get these 5" body catco metal cats? any links to websites would be great
https://www.sau.com.au/forums/topic/310712-cat-convertors/#findComment-5118040
Try Just Jap, they may not stock the big ones (a lot of places don't) but they should be able to source the one you need from Catco.
Let me know how you go as I will be chasing one soon also.
Cheers.
https://www.sau.com.au/forums/topic/310712-cat-convertors/#findComment-5118091
I think this is about the cheapest you'll find one:
http://www.fordxr6turbo.com/forum/100Cpi-R...598#entry986598
If you dont want to join the forum you can email chris on [email protected]
Oh and standard xr6t cats usually get swapped out between 270 and 300rwkw. I wouldnt try to push much more through them.
Edited by gregor
https://www.sau.com.au/forums/topic/310712-cat-convertors/#findComment-5118126
I was recently quoted $340 for a naked (unflanged) 5" body ballistic CAT. I am going to mate these to 3.5" flanges
Refer to below link for flow results (having trouble inserting as hyperlink)
www.surefloexhaust.com.au/cc.htm
Edited by gtr fan
https://www.sau.com.au/forums/topic/310712-cat-convertors/#findComment-5118230
Love a good naked cat - $340.00 seems reasonable.
https://www.sau.com.au/forums/topic/310712-cat-convertors/#findComment-5118235
You can get 3 or 3.5" inlets and its a 5 inch body, they are unpolished but stainless steel. I'm a member on there so maybe thats why you can't see it but just email him at the address i listed or join the forum and the link above should work. Chris runs rapid systems, one of the xr6 forum sponsors and he usually gives pretty quick responses.
https://www.sau.com.au/forums/topic/310712-cat-convertors/#findComment-5118260
yeh i had a little bit of a look at these and they sound ok but everyone can claim what they want. what ever one i end up getting it has to be able to flow 450kw and above
https://www.sau.com.au/forums/topic/310712-cat-convertors/#findComment-5118390
so what cats are you selling on your forums? xr6 ones or these ballistic cats???
also the link for the ballistic ones has no contact info for them, only product info, where can you buys these from?
https://www.sau.com.au/forums/topic/310712-cat-convertors/#findComment-5118396
https://www.sau.com.au/forums/topic/310712-cat-convertors/#findComment-5118466
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
