Hey photoshoppers, ive done some thinking and argueing with mates over the last few days and need someones help to do a basic color change
Could someone possibly change the front bar, and sideskirt to black.. IE to match the bonnet.
greatly appreciated, i know this wouldnt take more than a minute for some of you xpertz :P Ill be getting a copy of photoshop 7 soon to start learning for myself.
Thanks in advance
http://www.skylinesaustralia.com/gallery/a...lbum02/PA130019
https://www.sau.com.au/forums/topic/31072-some-help-needed/
Yea ill be leaving it, was just interested to see how it would look
I also thought of the back of the car.. The light surrounds ..
My color is like spec silver.. the exact opposite of Charcoal grey kinda
was thinking about getting them sprayed that grey, there only small so it wouldnt be more than $80-100 tops
do you have a picture of a silver R33 back end..
https://www.sau.com.au/forums/topic/31072-some-help-needed/#findComment-630360
