The paint in my engine bay is comming off and i wanted to respray it. That is the rocker covers, cam belt cover, as well as the plenum.
I wanted to know whether I need to take the stuff off or whether I could spray it on the car?
I know the plenum is really hard to remove and I dont know if i need new gaskets on any of the other stuff?
Edited by XTRMTY
https://www.sau.com.au/forums/topic/310757-how-to-go-about-painting-an-rb26/
Im also interested in doing this too
Im pretty sure the parts would need to be removed so they can be sanded and sprayed properly as it would look like a half a*sed job to do it with the parts in there.
pulling them off is going to give the best result as you can properly clean them as well as give them a good paint coverage so you aren't simply painting the top half and possibly having hard to get to, yet visible areas that aren't painted. also it will avoid any overspray making the engine bay look crappy
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
