A shit load of cash has been outlayed for this unfinished project, It has all gotta go, my unfortunate situation may very well be your gain!!
The head and bottom end has been assembled by JHH, however just not bolted together as yet!
Scat H Beam Rods
JE Pistons
JE Rings
ARP MSK
ARP HSK
Custom billet Cams built by Tighe (282) (490-specs)
Performance Valve Springs
$3950 (Reciepts Available)
Enigineering by JHH Performance:
Strip & Bath 2jz head, Reassemble
Strip head, clearance head for cam lobes, clean & reassemble, reset Tappets
Bore & Hone 2jz Block
Deck Block
Grind Crank
Balance Engine Assembly
Supply Valve Stem Seals
Assemble Short Engine (Clean & Inspect, Prep Block & Paint, Check & Set Clearances)
Supply ACL Race series conrod & main bearings
$2060 (Reciepts Available)
Parts Purchased, yet to go on:
1.8mm cometic triple plate metal head gasket-$400
HKS Timing Belt - $250
Plenum Intake Manifold - $1000
Oil Pump - $300
Oil Seals - $150
ATI Racing Harmonic Balancer - $700
Aristoe complete front sump baffles, pickup -$300
Heavy Duty Brass Button Clutch - $600
2000HP Billet Turbo from the states -$2500
All up with the cost of the original motor i am out of pocket over $13,000!!
Selling as whole package ONLY: $10,000 ON
https://www.sau.com.au/forums/topic/310763-~~~2jz-massive-hp~~~/
  • 2 months later...
    • Unless you have big cams, there is no reason for an RB to idle at any more than the stock 650. No, it is not 850, 950, or anything else. It is 650. In fact, it might even be 550. I just opened an arbitrary stock Neo file in Nistune, and this is what I see
    • I love the undertray, especially the flappy bit for easier access for serving I'm thinking of fabing up one at work for the MX5 while I still have access to the metal shop at work with a guillotine and press brake Whilst removing the plastic undertray on the MX5 isn't to hard, I love the idea of a 2 bolt flap as opposed to removing the whole thing
    • Great thank you for that. Yeah that is the bumper and spoiler it still has i just hadn't heard of it being referred to as a aero form bumper before. Really appreciate your help.
    • A little progress; I took the opportunity of an oil change to take a sample for oil analysis, will be interesting to see how it was treated for its first 125,000klm (I know how it has been treated since :rofl:) I went with 5w40 and will see what that does for oil pressure at higher revs. Also fitted the Z1 front undertray....a little more sturdy than the plastic factory one (although I suspect it won't stop a tree stump ) Nicest thing about it really is the 2 bolt "service panel"....a gift to the oil changer compared to removing 14 bolts holding the factory tray.
    • I think a scissor lift is better/faster in most cases, but I guess it does obstruct access to the centre of the car? BTW I weighed the quick jack. 3.5 tonne model is 50kg for each side. So yes, portable, but not with one finger
