hey all, im about to start an RB30 twincam conversion on my stagea, need some advice on who are the best people for the job. ill be doing all the engine removing/refitting myself, just need someone to modify my NEO head and do one last mod on my 30 block, then bolt it together. i bought a RIPS 4wd RB30 block, its all set up for the conversion except for an oil supply to run VCT because id like to keep it active.
so that and the head mods and they need to be able to tune it for me when ive got it all back together... car is 4wd which narrows down dynos in the area but if the shop is good enough and only has 2wd dyno, i can make it run in 2wd.
so who do people recommend? i know esp do good work but ive also been told they charge alot for it. at the end of the day, im not rich but i dont want a shit job either.
D.
https://www.sau.com.au/forums/topic/310778-workshop-advice-needed/
+1 for Pro Engines.
I think you'll find that ESP and Autotech (def Autotech anyway) will use Pro Engines for the head work and any mods there anyways.
In terms of tune just talk to the workshops and pick somewhere that you're comfortable with. There's good and bad stories everywhere.
not really, heard they still did a bit of work from home but now one of the guys, phil, has moved to bathurst so i doubt they're still doing anything. while we're on them, the main guy (name evades me) has a very very nice r32gtr... tidy and subtle. still has skylines performance on the number plate too...
pro engines sounds like the go at the moment, checked out the website and they make RB30 awd adaptors so i guess they know what they're on about. will get in contact with them and see how we go.
anyone else anyone can think of??
D.
Edited by pintaline
how much $$$ (at least) they charged for complete engine swap in canberra? just in general without any fancy headwork etc.
my 25de is dying and i got 25det neo ready to slap asap.
thanks.
Want to sell that dying 25de?
Edited by StinkyPoo
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
