Does anyone know what the maximum power limit of a standard RB26DET con rod is? At what point do they stretch/bend?
I have been offered a set to put into my RB25DET engine as an upgrade. So I need to know whether it's worth it.
Also you guys talk about Linished rods. Can someone explain what that is please?
Cheers Fellas :P
https://www.sau.com.au/forums/topic/31078-power-limit-of-rb26-rods/
I am told by relable sources and have seen GTR's make 450rwhp + on standard rb26 rods.
I am currently building a rb26 and not sure yet whether to upgrade the rods or not. I think it would be more for security. And with the forged rod been lighter it should revv a bit more freely as well.
I can say from a hands on experience that rb26 and rb25 rods are world apart. they have different shape beam the egdes are different also thicker and the most important of all is that the rb26 rod carry a masive bearing end as comparo to an rb25. As for power capacity is all depends on how well u tuned it. But big numbers have been recorded.
Merli, one place that comes to mind is http://www.skylinesaustralia.com/forums/sh...ead.php?t=28130
Steve-SST, who has played with many RB25s and RB26s, is quite adamant that they are the same in most cases, just some RB25s came out with weaker rods, but it appears from his posts that most had the same rods as RB26.
Very interesting read!
I suppose it's quite possible, as all RB25 failures I've seen from excessive power levels have been piston related, which THEN leads to the rods punching holes through the block.
I'm not so sure about the claim that "but some RB 25s have weaker rods but a lot have GTR rods" though... That just seems very iffy and unlikely to me.
Either they all have the same rods or don't. Or all Series 2 and on have RB26-spec rods, or something like that. The claim of:
The only real way is to pull it down but some RBs respond very well to boost upgrades-Exhausts etc and some don't, the ones that don't tend to be the dog motor as the head flows less.
seems like it's based on not enough evidence to me, and based on one or two RB25s grenading and resulting opinion that it had "weaker rods than the rest" and was a "dog motor"
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
