hi all. this sunday will be the 3rd v cruise that we'll have in wa. meet once again at city west carpark. yes it is a very short notice but im sure it will be a nice turn up as im really busy after the 14th for a while.
please give a heads up if you are able to make it.
where: City West carpark
when: 14.03.10 this sunday 2.00pm
how; by driving down your v or similar
why: to have some fun, meet new people and make the community grow
what: there will be a bbq once again so the heads up will determine the amount of food and drinks that ill buy. last time i had heaps left over =(
hope to see most of you guys there.
richard.
Edited by xtc
https://www.sau.com.au/forums/topic/310824-wa-v-cruise-rd-3/
pretty sure more will rock up on the day as it did last 2 cruises where i havnt printed enough maps...hopefully thats the case.
next time puma =(
great timing that your yellow licky is off shall see you there.
you will be there steve =)
glad u can make it again shane
2 days left ppl.
Edited by xtc
Pretty hard for me to refuse a cruise, was jus wanting a few more vs das all. Yea ok count me in Richard, will come wid a mate. might leave bit early though.
Im really worried bout my blu strip lights now, might take em off. Got pulled over the other day.Had 3 people inspecting the car, They even measured my new front bumper. I dono how i managed to get away without a sticker.
Oh and BTW invited my other frend along, he come thru wd his silver v coupe. So yea +2
Edited by CRISP 35
you are welcome steve, always a pleasure.
also, thz to all that made this cruise a great one. i can definitely say the V community is growing.
photos will be up tonight.
let's keep this up people. see you all in round 4!
yerh it has been awhile oaksey. funny thing was...no one at the first ever cruise showed up at the second one? lol. all new faces were at the second cruise. so imagine all the people from the first and second came... it wouldve been awesome seeing at least 20 V's just cruising...and the 350z's from the third cruise we just had...
also when the pics do get uploaded...you'll notice one thing, and that there is not a single silver that showed up which was a surprise! and majority was pearl white lol.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
