wish i was there. :ermm:
Next time we you guys should do a Big cruise up to Gero and stay the night. Like when we have the MidWest Show and Shine :yes: in September. http://www.mwshowandshine.com/
Victor Bro... your rims.... sooo good :blush:
hey paul, thz alot. how you been?
wish you were there...more V are getting done up and it's so good to see.
Things are good. Got my lightweight pullys on :blush: and in the mail yesturday i got my new 06 projector headlights.
Might be getting a new bumper in a few months. Getting rid of the kenstyle front bumper.
Great shots guys. Depending on what happens in sep I wouldn't mind going for a cruise
up in geraldton. The next one will be in a months time where I won't be too busy to
organise one, unless someone wants to organise an earlier one.
Hopefully I'll have my kit on by then.
yeah, i wouldn't mind too.we have heaps of time to plan and save up for it in September.
WoOO VERY nice!!!! =D
xtc... i have the same exact rims as yours... 19" advantis gold?
[1CGO 286] NICE!!!!! hahah i always see your car driving pass on albany highway turning into nicholson rd or going up towards the city...
Btw Paul are u Gona be selling ur current headlights once the projectors are in? I need a spare set to
experiment on something.
Yeah i'll be selling them.
PM me and offer a price. Poor condition (The lens has stress cracks all over them).
yerh it has been awhile oaksey. funny thing was...no one at the first ever cruise showed up at the second one? lol. all new faces were at the second cruise. so imagine all the people from the first and second came... it wouldve been awesome seeing at least 20 V's just cruising...and the 350z's from the third cruise we just had...
also when the pics do get uploaded...you'll notice one thing, and that there is not a single silver that showed up which was a surprise! and majority was pearl white lol.
[/quote
Yeah I would have thought people at the first would be at following ones, was a good day. Yeah silver is pretty popular, I think I spot a sedan but I would have thought there would be more. I was hoping to make it but knew I had a pretty full weekend, looked at the clock at 1:50pm and thought about coming but my car wasn't washed and I've some minor cosmetic things to get sorted out on it.
I look forward to seeing your kit!
Yea.. i had 18s gmax last time.. well 2 months ago... got them swapped from fabcar (my neighbour) :ermm: how much did u get for them btw... i swapped my old rims n paid 1.5k for it... O_O not sure if it was worth it....
Hey bebe, did you get the 18 Gmax's from Fab Car also?
When I bought my V35 from them I traded in my R33 which had 18" gmax (mesh) rims on it, I wanted them swapped over to the V, they originally said they could then they reckoned that I needed spacers for the front and they wouldn't do it cause it is "Illegal"
Tried to say that the premium rims on the V where worth more!!
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
