An oppurtunity has come up to get an rb25 block with crank, pistons etc all still there. Im throwing up two ideas, trying to put the rb25 bottom end in instead of the rb20 bottom end or using rb25 internals in the rb20 block. I've done a few searches but information is very slim. Can anyone add some light to the situation??
Cheers
Jayson
https://www.sau.com.au/forums/topic/31083-rb2025-combo/
that's a real pain, Any ideas about putting an rb25 block and internals in replacement for the rb20 block? With the 2.2 L did he just bore it out and put bigger pistons in??
Thanks mate
You wont be able to bolt the RB20 head onto the RB25 block without causing yourself a bunch of heartache. If you can get the RB25 block at the right price, you may consider getting an RB25 head and just going down that path.
Yeh, the RB22 is just bored out RB20 block.
https://www.sau.com.au/forums/topic/31083-rb2025-combo/#findComment-628718
Hi Mase, here's the go................
Use the RB25 crank and rods and set of standard 4AGZE pistons, that gives you 2.3 litres. The last set of used 4AGZE pistons I bought cost $100 for the set of 4, so $150 for 6. New set of rings was $20 per piston (AGE's are as common as). Balance all the up & down and round & round bits while you have them out.
Sell the RB25 block and pistons, you'll get most of your money back.
Stick a set of standard GTR camshafts in it (they are cheap), adjustable pulleys and with the right turbo it will fly. I have seen 260 rwkw out of this combo, with a good spread of power across the rev range. Unlike a standard RB20, which at 260 rwkw is very peaky.
Hope that helps
https://www.sau.com.au/forums/topic/31083-rb2025-combo/#findComment-634396
So the RB25/26 rods small end and 4aGZE pistons rod bushing/piston pin match up ok and also the piston height works out ok.
For every time i have read they bolt straight in i have read or heard that the piston pin needs attention or the piston requires machining of the head to ensure correct height???????
If thats the case id rather get forgies, sure the casting process of the 4AGZE offers improved strength over most other cast pistons, and i have also read that the 4AGZE (supercharged vs the 4AGE NA) pistons also have a form of ceramic/ treatment std, in which case any maching of will only further weaken the piston??????????
ALL SPECULATION AND THINGS I HAVE HEARD. If i had the bankroll i would love to go and find out for general info as much as my own sake. ;)
https://www.sau.com.au/forums/topic/31083-rb2025-combo/#findComment-634587
Depends on how far you want to go, how much DIY etc etc.
But for a reputable workshop to do the whole hog, you would be looking at $15k. Thats:
- Remove RB20
- New quality bearings/studs
- Purchase of 2nd hand RB26 rods and crank
- Forged pistons to suit your desired compression
- Increase the daim of the combustion chamber to suit 83mm bore
- Re-co of head, (Perhaps some new valves, valve springs and cams, GTR like Sydneykid suggested)
- The engine is being completely stripped so new gaskets
- NDT of block, crank, rods
- General machining/decking
- Balancing bottom end
- Re-assembly of engine
- Install new engine
Consider that many workshops charge $70+ an hour and you can see why it gets so expensive. Do much of the running around, do the nuts and bolts stuff yourself and you can save thousands...best to do your own numbers after talking to the people your comfortable using to do the work.
Your doing well to have it done for less then 6K
https://www.sau.com.au/forums/topic/31083-rb2025-combo/#findComment-635103
Hi Roy, I'll try and answer a few of your questions...
^ 4AGZE pistons require no machining to fit
^ I believe they are high pressure cast
^ The crown is ceramic coated
^ The skirts are coated with oil retention compound
^ The 4AGZE gudgeon pins fit the little end of the RB25/26 conrods, with very minor machining of the bronze bushes. This is normal stuff.
^ Ceramic coatings is applied to the crown as a heat barrier, it has no effect on the strength of the piston
^ All of the block machining and balancing similar to what you would have to do to make a 2.3 litre RB20 cost me less than $500.
^ Lots of RB30 (Commondoor) parts fit, made by Nissan sold cheap by 'Olden. Think gaskets, seals, water pump, oil pump, bearings etc
So if you can do the engine R&R and the assembly, it will cost less than $5K if you have to buy everything. If you have some of the stuff it will be even cheaper.
But Roy is right, if you have to pay someone to do it, you might as well do an RB31 because it will cost the same. For example a set of 82 mm forged pistons will cost the same as a set of 87.5 mm forged pistons. Balancing an RB30 crank costs the same as balancing an RB25 crank, etc etc.
So as much as I would like to build a 2.4 litre RB20, bottom line is I can build an RB31 for about the same. That's why I haven't done one......yet...
Hope that helps some more
https://www.sau.com.au/forums/topic/31083-rb2025-combo/#findComment-635425
Thanks Sydneykid, most helpful as always.
Just trying to be realistic with costs, as i suspect too much 'buck-fitty" stuff is posted here, and hate to see someone start down this path thinking it was a cheap option.
The dollars soon add up, main reason i am hesitant of building such an engine is that i would want to do ancillaries as well, so things like GTR oil/water pumps, better valve springs, bigger cams, to ensure that the thing can cope with sustained 8,000rpm track work. Which always makes like you said the RB31 option better, especially considering the flow benefits of the RB25/26 heads and ability to get away with lower rev limit.
Then i sit back and sure the power i have may be a bit peaky at the moment, but its still fun and its not like i do any competitive stuff with my car, my track days are purely "therapy" sessions so as long as im having fun which my car ....that said if i had the surplus coin i would do it all in a heartbeat. ;)
https://www.sau.com.au/forums/topic/31083-rb2025-combo/#findComment-635801
rb25 block $250 for me
I have an rb20det
pistons 4AGZE say $200
maching 20-30 per cylinder. worse case $180
new rings $120
Bearings $100??
blueprinting roughly $200
New headgasket (metal) $200
All labour is done by myself and a mate. My mate has done the rb30/25 to a mate's r33.
The other stuff like cams etc can be done at a later date right?
This is worse case scenario.
Then, i can sell rb20 crank and rods, good rb25 block and rb25 and rb20 pistons.
Thankyou very much for your help sydney kid, straightened up a few things.
https://www.sau.com.au/forums/topic/31083-rb2025-combo/#findComment-636171
    • I did read your post, a few times actually.    Done. Followed this step. [Negative probe should be on the cars chassis. Positive on the wire.]   Did this partially.. now that im reading this over, i only unplugged the LED lights. [Start as said above by unplugging everything (unplug the lights, and switches.] When you are talking about the switch, you're talking about the knob thing on the right side in the drivers seat right? If so, i need to take that apart?  [Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch.] At this point are you referring to the connector by the headlights?  [If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.] Did this. I can confirm that the LED lights aren't the issue [Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.]
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
