been searching and seaching cant find any.. found some SR20 ones.. but no skyline ones.. im trying to install some Ba thermos 2 my R32 skyline.. but the power steering pump line sticks out crazy.. i want to know what you guys did to get around this issue?
And lots of pictures of your thermo setups! cheers
This is not with the standard radiator but with the 42mm thick aluminium radiator I made for my R32. This fits 2 14" fans side by side, The side bands have circular wings to prevent leaking of air being drawn by the fans
Edited by salival
double post fail :D
Edited by salival
still looking for some photos of your ford thermos =)
i got the same setup as salival because the 42mm radiator and ford thermos would not fit. and i had to cut the bracket off the ps pump that holds the line facing forwards so i could spin it across little to get some clearance. i got rb25 in a 32 with lower engine mounts, and there is f**k all room in the front. so good luck with the falcon thermos. there like 150mm thick.
hmm i sware a little wile ago i had seen some on here.. i think if u cut the thermos down i might just get the clearance its gonna take alot of chopping.. i donr know what eles to try... i cant fit the standard shroud back in cuz the radiator is too thick!
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
