yeah i was going to get a split system installed in my room, but no wall space!
im waiting for my uncle to gtfo so i can set up my sim, mount my tv on the wall in my room. lcd + g25(might upgrade to a g27) + ac and ps3 = bliss
Guest
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
