Lol that's cuz I've been there 100 times more than you!
i know. its still new and shiny for me. and i loves it. and i wants it.
The only thing you go to Rock Kung for is duck...everything else they make is shit and overpriced compared to China Bar. Yes the service at China Bar sucks...but the food makes up for it.
lol china bar is overrated. there are other places on that strip that have good food at slightly lower prices.
attacking my brakes this weekend. who wants to help?
Better be putting some nice slotted rotors on there!
slotteds, new pads, new fluid, and painting the calipers if i can. never attempted something like this so will be an interesting exp
Really not bad to do. Just have to make sure you bleed the brakes properly. Otherwise your brake pedal will be spongy as f**k and the brakes won't be working that well lol
I'm bleeding my ABS system on the weekend, so if you want come over. I got all the tools n stuff you'll need.
Also, china bar is great if you've never had proper hawker food... ie if you're white :) You don't go to RK for the service or the hygiene. lol gtfo with your culinary critique, we go there cos its cheap, and is done exactly how they do it in the motherland.
I changed engine (and therefore driveshafts/rotors/hubs/etc) without bleeding - just had to push the calipers open coz someone pressed the brake pedal while everything was out....
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
