actually its fine as it is, as the power to weight rule is based on factory specs
ie they dont dyno your car or engine dyno the engine output
no! no it isnt!
atleast now, theres a nicer choice of cars for me :)
now i can stop being an idiot and having f**ked up ideas..
wait. im always an idiot :) (not when im driving though)
edit: anyone know what the weight of an R34 GT-Four sedan is?
Edited by GTR-boy
no! no it isnt!
Doesn't matter because they are legal. R34gt4 is n/a
Awww yeah... P Platers with Legnums and Stageas. Suck it up TJ, drivers like you are about to get targetted.
the power to weight rules are based on factory specs of the car
ie you cant drive a 5year old xr6 turbo because you think its lost %10 of its power over 5 years and it all of a sudden comes under the rule. if the car is tagged being over, then its over regardless of how old it is, how many km's are on it and what mods it has
theres an idea...
that dino gear knob is just f**kED
thanks for the answer crispy :down:
Edited by GTR-boy
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
