From 6 July 2009, drivers issued with a probationary licence on or after 1 July 2007 may drive some lower performance turbocharged or supercharged vehicles. The definition of a lower performance turbocharged or supercharged vehicle is a vehicle with 6 cylinders or less that is;
  • turbocharged or supercharged with a power to weight ratio of less than 100kW per tonne;
  • turbocharged or supercharged with a power to weight ratio between 100kW and 125kW per tonne and that is considered to be a family type vehicle (4 seats or more) rather than a sports type vehicle. A family type vehicle is a sedan, station wagon or hatch normally used to carry families/passengers with 4 or more seats and are equipped with child restraint anchorages. A family type vehicle does not include a sports car (two door coupe).
soo can anyone recommend something thats fun to drive that is within those rules?
Does the law mean that under 100kw & turbo is fine but if its 100-125kw/tonne then you need to apply for an excemption?
If thats the case find a turbo car under 100kw/tonne will be easier I guess.
Starlet GT or supercharged aw11 mr2 are two fun cars. Im assuming they both fall under 100kw/tonne
why not get a vl turbo ? it would be under the kw rule, cheap, and you have zero chance of finding a stock one, so it should be "fun"
i mean 21psi is "low boost" on a vl turbo these days
id recommend some good tyres though
hahahahahhaahahha realllllll funny
shan. i would hate to know what you were searching for when that came up
in that case, i would f**kin hate to know what that guy was up to..
on another note.
5 13 pages of VCD annotation, 30 generations to be drawn up, 10 developments with annotation and then i get to finally start the project. FML
why hahahah ? it was a serious suggestion
there would be dozens for sale, they are cheap, last forever
the base power output vs weight would keep it under the rule
and almost all of them would have mods, so its still within the rule (based on factory specs)
its a VL turbo man... i hate those things with a passion
