be worth it if u can grab a plasma or two..
n/a turbo who r u? and a little bit contradictory dont u think.?
http://www.skylinesaustralia.com/forums/18...21#entry5073721
dont think its that contradictory.
wow, that impressed by his story huh? i thought it was pretty shit personally. needed more camber.
hmmm good point. let me tell you about a story that happened on the weekend. i was at a party and my mate was talking to some chick, he came over and said that she was interested in me and and wanted to know if i was single, i thought ok cool, i turned around and she came over and pointed at me and said i wasnt talking about him, im interested in the guy he's sitting next too! i died a little more inside so i walked outside and saw a chaser with huge camber and to get rid of my frustrations i jizzed all over it and continued to party. and thats my life, thanks for listening.
now with camber
epic story now has epic stance. well done.
+ liked.
im referring to ur name.. n/a Turbo, id assume its either n/a OR turbo thus the contradiction.
to be nomenclaturally correct, it'd probably be "Turbo'd N/A"
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
