Vic Wasteland Thread
paulr33
nope... doesnt have to be done by a compliancer.
its already complied... i want extra points put in, probably should have mentioned that
there's some uglay ass and stock r32's in that bunch. canadians seem to have the most win out of all that, guess they've got US spec stance and Japan spec cars.
Yeah I know,
Hope mine looks decent.
AUS, Canada, NZ and Euro seem to love their R32's.
Canada has good stance NZ has good drift pigs LOL!
just do em yourself. get the right bolts and parts from nissan (like $10 bucks from memory for maxima ones)
i was going to get max to do it... dunno if he has time at the moment, as always hes busy non-stop with his restorations.
might pop it up on the hoist and see what i have to do... if its as simple as welding a couple of those bolt plates in i'll do it myself.
I complied a few cars and all we did was tap a thread into a structural part and bolt a hook into it. then again they already had allowances for mounts on the chassis. Depends if you ahve to reinforce the area. Ask your compliancer, they should know.
nah r33. its a skyline. it looks better than an R32 GTS, looks heaps better than an R31.
i know its gona be slow n shit but mehh...
would look tops resprayed in the red thats on 350z's with pulled guards, GTR front bar. S2 grille + headlights and old school meshies. sitting nice and flush.
fuck off. you're going full retard if you waste a cent on an N/A R33. Everything you spend on it should be unboltable when you want to resell it (and you will, no one ever gets attached to an N/A R33). This means no respray, and no pulled guards. Stop wasting money, and living pipe dreams.
LOL!
Worst Skyline ever made.
why not go r34, it shits on all the other models :laugh: .
on another note its such a nice night i can hear all the fags trying to do burnouts in there commodores, i hope they lose there legs because there cars sound sooooo shit.
where u live ?
f**k off. you're going full retard if you waste a cent on an N/A R33. Everything you spend on it should be unboltable when you want to resell it (and you will, no one ever gets attached to an N/A R33). This means no respray, and no pulled guards. Stop wasting money, and living pipe dreams.
i said it would look tops.. i didnt say i would do it! :D
nah its just gona be a decent set of wheels and a GTR front bar(i hate the gts/t fronts)
lol gtr-boy you'd buy the farken heavy slow n/a R34 or the GT-R only without ever havin driven the other models? you should stick to your hilux :huh:
R34 GT-4 + RB26 = 4 door GTR
drove an auto R33. and the hilux is just sitting there. just want the damn thing gone. got it listed for 3k
R34 GT-4 + RB26 + turbos + intake + front pipe + flywheel + clutch + wiring loom + ECU + brakes + diffs + exorcist + hub assemblies + brake booster + gearbox + ATESSA controller + dreams + G-sensors + radiator + radiator support + hopes + bumper support + bumper + front guards + rear guards + respray + bonnet + instrument cluster + GTR dash insert + dash mounted gauges + fuel pump + fuel regulator + water pump + oil pump + alternator + starter motor + prayers = 4 door GTR
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
