Vic Wasteland Thread
paulr33
I don't use the PS3 for it anymore, but when I first got it I was watching PC files through the wireless network on it, they'd freeze randomly etc...
Now I just use the USB slot on the TV, works perfectly
still using WD HD Tv the first gen unit
works great, no issues and love the simple interface and how it works
only bug is no ethernet or wireless so just got two usb drives perm plugged in
thats all good for normal def movies and tv shows in DIVX format... but it wont play 720p and 1080p mkv files etc But i suppose if you dont have any then thats not an issue
yeah have no real dire need for 1080p blah blah
i just watch normal divx's download on cheap $50 dream speakers on a yamhaha stereo amp
havent even botheredd with surround sound and opticla out etc
i decided to attack the front yard 1 day. 1 shrub down, cbf anymore. im gona go play cod 6 lol... the half hacked tree is still where i left it hahaha
Trees down, neighbour unhappy
In other news... picked up a 2002 MK4 Golf for $5000. Thank you hail damage. w00t.
Now to panel beat the shit back up and respray it for re-rego inspection, then install airbags, meshed wheels and boser kit. should scrape in under 10K all done.
as much as i would love to. i gota rip everything out, get it level and law down some turf. tossing up between getting fake grass or real grass..
get good buffalo grass. fake grass never looks good IRL, only in brochures and magazines.
why the wheels and boser kit if your gona sell it?
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
