Vic Wasteland Thread
paulr33
Tell Blipman that :)
I do, on a regular basis. That's why he went and bought an R33 ;) Anything's an upgrade I suppose. Then he got a 180sx and then a Smellsior. Also if you see Ben, tell him I said hi, haven't seen him in over a year now.
fugly fairladies:
1. 280Z
2. Z31
3. Z32
I've never met him. Just occasionally interact via the aus300 forums.
I agree on the Z31 for sure. I can't see anything attractive in that car. Does absolutely nothing for me.
Blipman's Z32 was pretty nice I reckon.
What's wrong with a VH45?
LSx's are lighter, cheaper and more reliable.
oh... lol yeah I used to sit about 2m away from him every day at work for a year n a bit. reminded him almost every chance I got.
I've got a nice 300ZX right here for you :P Haha.
:P
Even if it was twin turbo, I would not take it.
congrats, you own the 3rd ugliest Fairlady of all time.
:cool:
I do, on a regular basis. That's why he went and bought an R33 :P Anything's an upgrade I suppose. Then he got a 180sx and then a Smellsior. Also if you see Ben, tell him I said hi, haven't seen him in over a year now.
fugly fairladies:
1. 280Z
2. Z31
3. Z32
LOL!
Only reason I would take a 280ZX is cause at the time, it was hard to a 240Z / 260Z.
I would still prefer a 280Z over the Z31 and Z32.
At least it retained some of the classic shape / styling lines.
240Z / 260Z = all time best Fairladies!
Not much of a fan of the newbie 350Z and 370Z's either.
given a supra, 300zx and a mr2, I'd probably take the mr2 over the lot. fuck driving land barges off. at least an MR2 turbo is zip zip fun times.
i automatically assume anyone driving a 300zx is in their late 30's and working some entry level job (can't afford anything better).
poopra drivers are hard to predict, they're either tossers like 3 series BMW drivers or they're guys who love drag racing but got snotty with the fact that power windows don't come factory on commodores.
:P
Your opinions amuse me and the fact that you are usually spot on.
:cool:
I think you should sell it and the Supra and buy a GTR.
Yeah. Will be R32 GTR or a modded MR2.
There seems to be alot of MR2s popping up for sale now with forged rebuilds and everything done. They're going for relatively cheap too. Much much cheaper than a GTR.
So when the time comes I will look at the wallet and make my choice then. Either way I'll be happy.
I've never driven a GTR but I did drive Chad's GTS-T and loved the feel of that. Have driven an R33 and it really did nothing for me.
I think I just prefer slightly older cars.
Edited by jezza boii
Sounds like a plan!
a GTR is nothing like a GTSt. nothing. they just have the same headlights.
True that!
wait till you drive one.
Hell I even got to drive a 200ZR with an RB26DETT and I was like "sweeeeeeeet", started the car and took a corner and went "FFFFFFFFFUUUUU".
first day at cadbury = great success
First task was taste testing cherry ripes :cool:
Picked up 5kg of Picnic for $8, will get a box of boost tomorrow :P
haha you're so getting diabetes.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
