i looked at rotas.. then looked at some rota broken pics.. and like mmm..
yeh funky there +12 the bottom is +21 and looks mint enough, also low so should be ok, he didn't state any spacers.
i was thinking of buying one of the rear diffusers from psiparts, but unsure of how low they sit.. i like them but if it looks retarded with stock body then hrmm..
yeah look not a big fan of the Rota's either, but those boys have to rep the wheels they sell in their shop otherwise their customers will go "why aren't you using them if they're so good?"
but as far as stance and fitment goes, that 32's done right... even for a GTSt.
dear alex,
fuck off.
kind regards,
shan
please don't weigh in on this when your choice of cars include a poopra, a 300zx and an MR2. :P
:happy:
i like my whale anyways.. plus 32s are nice but such a small % are done right
dont all be jumping on the rota band wagon now you know they suck
Tuff fitment Alex!
Shan, what car is this?
also...
wot?
he has Face 2 +12's all around.
you have Face 1 +21's all around.
your wheels are sunken in by 9mm compared to his, AND you have lower brake clearance cos the spokes on your rim run straight and not curved (hence the different Face's). He isn't running spacers. You may have to, cos it may hit the shocks. You may not have to, you'll only find out when you get the wheels... but regardless your wheels will sit roughly 1cm further into the guard compared to his unless you run spacers.
comprende?
so could organize a half cage for me? bolt in street legal?
don't make bolt ins. race cages or GTFO. we get secondhand safety 21's from time to time... call roshan (0425855540) and find out. tell him shan asked you to call him, and also remind him that he's a giant knob jockey.
also...
wot?
comprende?
yeh i know i was just talking about the car in the bottom 2 pictures :)
I love when the R32 V R33 debate sparks up. Most of the 32 fans will find some of the best looking 32's around, post photos of them, and then post photos of white/burgundy s1's with stock wheels and no kit as a comparison, or a veilside kitted 33...
Having said that, before they start crying, I've been contemplating a 32 GTR...
lol my 32's not a looker by any means, so I don't post it up. But its like the perfect wife... knows how to take a solid beating like a champ and keeps on working without attracting attention to itself.
what? :)
although with these wheels I'm bidding on, GTR fenders, shaved bumpers, CF bits and paint, it might stand out just a touch.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
