i looked at rotas.. then looked at some rota broken pics.. and like mmm..
yeh funky there +12 the bottom is +21 and looks mint enough, also low so should be ok, he didn't state any spacers.
i was thinking of buying one of the rear diffusers from psiparts, but unsure of how low they sit.. i like them but if it looks retarded with stock body then hrmm..
yeah look not a big fan of the Rota's either, but those boys have to rep the wheels they sell in their shop otherwise their customers will go "why aren't you using them if they're so good?"
but as far as stance and fitment goes, that 32's done right... even for a GTSt.
dear alex,
fuck off.
kind regards,
shan
please don't weigh in on this when your choice of cars include a poopra, a 300zx and an MR2. :P
:happy:
i like my whale anyways.. plus 32s are nice but such a small % are done right
dont all be jumping on the rota band wagon now you know they suck
Tuff fitment Alex!
Shan, what car is this?
also...
wot?
he has Face 2 +12's all around.
you have Face 1 +21's all around.
your wheels are sunken in by 9mm compared to his, AND you have lower brake clearance cos the spokes on your rim run straight and not curved (hence the different Face's). He isn't running spacers. You may have to, cos it may hit the shocks. You may not have to, you'll only find out when you get the wheels... but regardless your wheels will sit roughly 1cm further into the guard compared to his unless you run spacers.
comprende?
so could organize a half cage for me? bolt in street legal?
don't make bolt ins. race cages or GTFO. we get secondhand safety 21's from time to time... call roshan (0425855540) and find out. tell him shan asked you to call him, and also remind him that he's a giant knob jockey.
also...
wot?
comprende?
yeh i know i was just talking about the car in the bottom 2 pictures :)
I love when the R32 V R33 debate sparks up. Most of the 32 fans will find some of the best looking 32's around, post photos of them, and then post photos of white/burgundy s1's with stock wheels and no kit as a comparison, or a veilside kitted 33...
Having said that, before they start crying, I've been contemplating a 32 GTR...
lol my 32's not a looker by any means, so I don't post it up. But its like the perfect wife... knows how to take a solid beating like a champ and keeps on working without attracting attention to itself.
what? :)
although with these wheels I'm bidding on, GTR fenders, shaved bumpers, CF bits and paint, it might stand out just a touch.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
