Apparently announced on Instagram just this week; I can't access it and nothing on their website Their GTR TCM information is here: https://ecutek.zendesk.com/hc/en-gb/articles/360001830657-Tuning-Your-TCM
By DraftySquash · Posted
HA!!! Having the same issue so dropped the car off at Chasers Performance to get the codes. I could never give it gas while turning. And it stalled at lights for the first time on my way to the mechanic today! -
By 180 wanabe · Posted
Pretty sure that the Ecutek can also tune the TCM for quicker gear changes as well -
So these motors don't seem to have as big issues with DI port carbon as others do. I also had a good run with my VK45DD cima, it did develop a light missfire at idle at around 300,000klm so I started using the subaru upper engine cleaner with each oil change and it improved (still happened occasionally) So, my plan with this car is to add a catch can, do upper engine cleaner with every second service (ie every 10,000klm) and see how that goes, I'll pull the intake off sooner or later and have a look at the valves too. On the ECU, you need an Ecutek tune; the Redsport ECU will expect sensors (turbo speed) and the 2nd water pump that the base model doesn't have...but I'd expect a tune (mostly more boost) is all you need to get there.
Checked for codes on the standard ecu. But not much else. What’s the procedure for TPS voltages? What else should I be trying to diagnose? cheers
