Anyone know of any electrician jobs paying 90k+ based in Melbourne? My current job is really giving me the shits, having to travel interstate at least a couple of weeks a month, when it should be shared around with the other tradesmen. I feel like a f**king puppet at the moment...
Just a few ideas that are going through my head at the moment. Just being overworked to the bone, when I was told that work would be shared around has really given me the irrates. Not to mention the full-blown argument that I had with both my bosses. Probably won't end up leaving, but just weighing up my options.
Might see if I can get into cruisy construction work again :)
sorry to hear juliette
hope its something simple, if there is no grinding, no chucks of cogs etc surely its something simple
on a good note all our plastering is done, finito! rangehood ready to go back in, all roof panels fixed (were sagging) and holes fixed up
tomrorow sanding mission and then undercoat and done wooohooo
Does anyone have any spare 3inch silicon hose bends? Im after a 90degree bend or 45degree bend, just want to borrow and/or buy if it fits!
My airpod sits too high and hits the bonnet, want to put a bend between the AFM and airpod so its sitting inside the vacant space where the airbox was! (or a bend between intake pipe/afm whatever works)
Plz help!
Thanks <3
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
