I had no power steering in mine for a few weeks. It doesn't bother me that much :P You get used to it and don't notice eventually.
My workmate has no PS in his MR2. Has gone without it for 15 years and loves it like that.
Also, less weight :thumbsup:
When you're moving faster than 10km/h there is no noticeable difference IMO. The only time it's a bitch is when parking.. but you just let the car roll a bit and it's fine.
Like I said, you get used to it :thumbsup:
chuck G-Parted boot disk in the drive, plug a USB hard drive in, turn it on, when it boots into the UNIX recovery OS, launch file browser and copy your files to the USB drive.
Then move it to a new computer or try and resurrect your old one.
There is already a disc in the drive and it won't eject :( Any ideas how to get it out?
finally burning some new music for my car
over the radio and the same cd ive listened to for about 8months
my car has alot of cd's in it, but they are all burnt, i keep the originals at home. atm im listening to nofx. no doof doof music ever in my car, only punk rock :(
I had no power steering in mine for a few weeks. It doesn't bother me that much :whistling: You get used to it and don't notice eventually.
Also, less weight :P
I've had no PS in my Commodore for about 6 months it works every now and then which is a real pain in the ass, the wheel moves too much when you expect it to move only a little. You do get used to it though, does give you bigger forearms though :(
hey fag i sent it through
just printed it and noticed it needs your name and sig n shit. thanks anyway.. ill check if the importers near my school have anything.
i wonder if they would approve it even though im still on my L's
oo i got a reply from Recochem
200Ltr drum of 100% denatured industrial ethanol = $437.25 + GST
Equates to about;
$6.60 per week (3Litrs/week)
$3.00 per week (3Litrs of dimineral water/week)
$9.60 per week
Now is this worth the 30-40kw atw gain O_o
my car has alot of cd's in it, but they are all burnt, i keep the originals at home. atm im listening to nofx. no doof doof music ever in my car, only punk rock :P
not a fan :(
hmmm why my name and sig? If your the one that wants the car to be able to drive
the person that ownes it is only selling it
Equates to about;
$9.60 per week
thats on a 60litre tank though
the evo only has like 47 i think and only about 40-42 is used when driving before the fuel light comes on
so works out cheaper if i do it :( haha
not a fan :(
fair enough everyone likes different things. what music do you listen to?
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
