Vic Wasteland Thread
paulr33
just another ARM based board.
If i could load Nistune onto it and hook it up to my ecu, could do map changes on the fly. Eat your heart out powerfc hand controller :P
... or you could probe the ECU's input/output signals and just make it do what the ECU does via emulation.
your car's ECU is the PC equivalent of a 386. ARM processors can do 1000 times the calculations that your ECU can do in the same time.
haha sounds like too much work.
Id be happy with map switching :P
Not sure nistune would run on windows CE though..
aren't you an engineer? get on it.
haha different stream. Never dealt with computer/mechatronics/electronics engineering
you do it for me. I'll give you a six pack :P
Removed the wing a gave my 33 a polish was quite chuffed with it really. A bit un-decided about the 'No-Wing"
gave the headlights a polish as well to get rid of the brown/orange tinge and the results were amazing
boo time for work :D
water pump, Gates timing belt, idler/tensioner bearing, cam seals, crank seal, fuel filter, thermostat, bearing stud/bolt kit - Thanks Kudos Motorsport
adjustable cam gears - Access Autoworks
and possibly a 52mm allum radiator from ISC
Damn you 200,000km service :)
