Just making sure you know that CAMS approved half cages are rear half, not front half.
http://www.camsmanual.com.au/pdf/10_gen_re...dule_j_q210.pdf
of course its rear half.. why would i get front half :)
yeh its approved and shisss it seems steep but aint no1 else got them that i can find. this guy wrote the RWC manual on roll cages so he knows his stuff at least, not that i care overally im a defect waiting to happen :P
902 is unfitted to but probaly chuck it in with mates
i do, i get along with most people on here
yeahh i try not to offend anyone on here.. wouldnt be good
although i do hold a grudge against shan for changing my username to ladytron ages ago...
kent :P
For reference, I payed $950 for a half cage, with harness bar fitted in my 180sx from BD. Mind you it was about 2 years ago now though.
Since when aren't bolt in CAMS approved Shan?
I had a half cage bolt in from Brown Davis, and it came complete with CAMS paperwork and never got pulled up with scrutineering.
alr33x:
Their work is awesome, so I highly recommend them, but they need a few lessons in customer service :P
since the 2005 handbook (section J) from memory (I could be wrong haven't looked at it in a couple of years). depends on the event you're competing too, half cage is fine for speed events, but for rally etc you need full cage.
Also just cos its CAMS compliant doesn't mean it is ADR compliant. Guess it all depends on what you want the cage for? street or track?
thanks man
its for drift events and street.. according to BD its fully compliant and street legal but meh.. doubt mr.plod will listen to that anyway was just wonderin about price and if their stuff is decent more so.
to get from japan will be 1k++ easy plus i was told streeter doesnt do cages so then gotta go to importer who will wana make a cut as well :P
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
